Old 11-18-2018, 02:39 PM   #1
81turbota
What’s going on with my motor mount towers? Pics
Hello everyone, I’m in the process of teardown for my 6.5TD swap.
I bought some used 1971 BBC motor mount towers and they look much different than my 1971 Blazer SBC mounts. Did I get the wrong parts or is my Blazer frame swapped? SBC Mount in first pic, BBC Mount in third.
James
James
1971 Blazer 350/SM465/NP205
1966 Chevelle 468/TH400
2009 Corvette Z06 built LS7
81turbota is offline   Reply With Quote
Old 11-18-2018, 03:49 PM   #2
1rippen6
Re: What’s going on with my motor mount towers? Pics
Yours is 4wd you I'm guessing your BB mounts are for a 2wd. I put a BB in one of my blazers years ago and used the same mounts as the small block.
1rippen6 is offline   Reply With Quote
Old 11-18-2018, 03:53 PM   #3
81turbota
Thanks for the response, Rippen. I need to have a little higher clearance with the 6.5TD.
Has anyone used the CPP BBC mounts? They look like they have the 4 bolt pattern like my originals.
James
Old 11-18-2018, 04:09 PM   #4
K20super
The diy4x cross members you can get one inch taller mounts for that is what I did for my big block swap.
K20super is offline   Reply With Quote
Old 11-18-2018, 04:11 PM   #5
81turbota
Those Diy4x cross members are nice looking! I’ll check them out, thanks for the tip.
James
Old 11-18-2018, 04:13 PM   #6
K20super
I forgot to say you will have to call them to get them they weren't on there website when I ordered mine last spring.
Old 11-18-2018, 09:52 PM   #7
kwmech
You can use the 2wd stands but, you'll have to redrill the frame for the bolt pattern and fab up the lower piece so you tie the bottom of the mounts together so you don't bend the top of the frame when you put engine in. This only works with a lift kit, otherwise the oil pan can come in contact with the diff
