6 lug wheels
I’m looking for some advice on some 6 lugs wheels that are a timeless look. Found some rally’s in 18”, which I think will look pretty good, but wanted to see what everyone was running on. My truck is lowered 3-5 and it’s time to add a little more to it. Thanks for the input. I’ll post a picture of truck in a little bit
Re: 6 lug wheels
I have reverse chrome wheels, but want to change back to stock rims with hub caps or 15" Rallye Wheels.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
Re: 6 lug wheels
2.5/4 drop on 15x8 rallies.
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
How did I get this OLD!
![]() Join Date: Dec 2014
Re: 6 lug wheels
Stock ride height 15x8 on the back 15x6 up front
http://67-72chevytrucks.com/vboard/a...1&d=1542580541
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Mechanical Diesel Tach, Vac, Kilometre Speedometer, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Steering Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt, Chewychevy67. |
Re: 6 lug wheels
There just aren't many options for 6 lug wheels. Anything newer has too small a hub pilot hole.
Best thing you can do IMO (and what I did) is swap to 5 lug. I did the ECE 5 lug disc conversion which is $100 cheaper than the 6 lug then used the savings to go towards a 5 lug rear axle which I found for $150. Then you have real options when it comes to wheels.
Re: 6 lug wheels
these factory wheels fit good.i think these are later 70's model k wheels.
![]() Join Date: Jan 2007
Re: 6 lug wheels
can't go wrong with 6 lug slots...
taken from a prior post here -> http://67-72chevytrucks.com/vboard/s...d.php?t=497291 |
![]() Join Date: Dec 2013
Re: 6 lug wheels
American Racing Aspen Sprint 18"
Re: 6 lug wheels
Thanks for all the reply’s, right now the truck sits on rally’s with baby moons. Want to go try and go with a bigger size rally like a 18- or 20 but not sure
![]() Join Date: Dec 2012
Re: 6 lug wheels
I'm fond of the car style rallye wheels with trim rings and caps..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
BlahBlahBlah
Re: 6 lug wheels
Nothing more timeless than an 18 inch wheel, LOL!
Just yanking your chain =) I like your truck as it is right now. Its such a good start I'm sure whatever you decide its going to look great. |
Re: 6 lug wheels
Yea yea yea, I guess what I should have said classic style but larger in diameter vision makes a 6 lug rally with car center caps I like just was seeing what everyone runs
#13 |
Re: 6 lug wheels
I had to grind my calipers for these but then again I have light 3/4 front brakes now. 4-nib 15x8 OE
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#14 |
Re: 6 lug wheels
I just put these wheels on my 70 step. Only I used the flat center caps.
1968 c10 swb Stepside |
#15 |
Re: 6 lug wheels
#16 |
Re: 6 lug wheels
Sweet...
#17 |
Re: 6 lug wheels
I do but can't figure out how to post them.
#18 |
Re: 6 lug wheels
#19 |
Re: 6 lug wheels
Do you have any Japanese 4x4 s or pickups where you are? 6 lug wheels are same fitment. They are plentiful in the uk
#20 | |
Re: 6 lug wheels
We do. I’m just looking for that particular look. I think I found a truck on Instagram that has them in 20s not really sure if I like them or not. I’d like to see the 18s comparison. |
#21 |
Re: 6 lug wheels
these are 18 rev wheels
#22 |
Re: 6 lug wheels
#23 |
Re: 6 lug wheels
See if this works
#24 |
Re: 6 lug wheels
That looks great! What size tires? Small drop?
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
#25 |
Re: 6 lug wheels
| Bookmarks |
