Shoulder Belts on 67 CST
Saw this 67 CST for sale locally today. Buddy buckets and factory seat belts? Just wanted to see everyone’s thoughts on the belts! Unfortunately no spid. Seat belts are dated late 1966.
USA#1 |
Re: Shoulder Belts on 67 CST
Also had plugs in the floor where lap belts would mount
USA#1 |
Someone else will have more detail but... the shoulder belt mount point was installed in all 67-72 C10s. Whether the 3 point harness was an option in '67... I'm not real sure but it was certainly available as an aftermarket upgrade for anyone back then that wanted it!
However, I strongly suspect that since GM installed the anchor, the belt would have been available as an option at order time. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Moderator
![]() Join Date: May 2007
Someone took the plug from the pillar and put it on the floor. The factory shoulder belt should have a rubber boot retainer and the mounting buckle end should not be bent like that.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
GM Addicted
Looks like they moved belt from floor to the upper cab mount
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
FYI... I have no idea what the law in CA is but in TX, even though the '67 did not come with shoulder belts standard ( and is therefore exempt from the seatbelt laws ), if they are installed in the truck the driver/passenger can be cited/ticketed for NOT wearing them! -klb
Moderator
Laws the same here.
Yeah, someone slapped some lap belts up there. The spid will tell you if it originally came with shoulder belts.
72 C10 lwb fleetside -stock 350/350 combo |
man that would snap your neck on the way to the steering wheel
Weren't the factory 3 point belt a 2 piece design? With 1 buckle for the waist and one for the shoulder.
AJC |
Moderator
They were two separate belts, two separate buckles, and a pain in the a$$ to use
There wouldn't be shoulder belts without the lap belt. I too say the belt was moved from the floor to the cab corner
#13 |
Junior Member
![]() Join Date: Nov 2018
Hey Guys - I'm new to the forum and new to C10s too. Just bought a 69 C10 Stepside and noticed the circular tab at the top of the B-pillar. If I understand this thread correctly, you're saying that is intended for 3 point seat belts? Punch out the tab and there's a welded nut behind it?
Thanks Ken (Was a Ford guy until I fell in love with this C10!) |
#14 |
Moderator
It is threaded and you can add modern 3 point belts for safety. Welcome to the board!
#15 |
Junior Member
Thanks leddzepp, That's what I was hoping for. My 69 is bright red stepside with power disc brakes, A/C, and power steering. Still has a strong 250ci inline6 and 3 on the tree. Will post pics when I figure out how. Thanks again for the reply.
Ken (aka Flattie39) |
#16 |
Other than using different mounting hardware, this is all GM did for their factory option belts...with an absolutely necessary lap belt as well. I've gone all the way and built a few trucks with the factory shoulder belts. Was a fool for finding/buying those for years...had to have them! But after using these trucks I decided factory shoulder belts are great for a show ready restoration, but in the trucks I drive I'll take the modern aftermarket (or factory) 3 pts. Same as radial tires, good tunes, battery... there are better alternatives when vehicle is actually used to drive. I'd like to make that chrome 3-way male piece of buckle and have some proper 3 pts made up using stock width & original buckle. If a seat belt company would make a set like that in original colors they wouldn't be able to make them fast enough.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-21-2018 at 09:21 AM. |
#17 |
![]() Join Date: Mar 2017
Does anyone have any favorite aftermarket shoulder belts? I am adding them to mine. Thanks
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
#18 |
![]() Join Date: Sep 2007
if I remember correctly, some guys use the 3 point belts from the square s10`s
1967custom |
#19 |
Old member
I used 99 Tahoe seats and belts in my 71 and 89-90 model seat and belts in the ramp truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
