Old 11-19-2018, 01:09 AM   #1
bh86
Where to find correct perforated vinyl headliner material
I'm looking for perforated vinyl material for 2 different trucks that came with them originally and would like to keep them original as I really like the look of the vinyl headliner material. First one is a blue 79 GMC, and the second is a two tone red 81 GMC. I attached pics of each in case that helps. I usually would get this sort of thing through USA1 but Randy said the company he had been getting it through no longer carries it. Anyhow lemme know if anyone has a connection on where to find it. Thanks!!
bh86 is offline   Reply With Quote
Old 11-19-2018, 01:19 AM   #2
Dads79GMC
Dads79GMC's Avatar
Re: Where to find correct perforated vinyl headliner material
I just Googled "perforated foam backed vinyl" and got this right away:
https://www.ebay.com/itm/Auto-Headli...-/261993774731
Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 11-19-2018, 01:57 AM   #3
bh86
I was told that the Marine stuff was too thick. Does anyone know if that's true? It needs to be foam backed but that foam is quite thick.
Mike
Old 11-19-2018, 06:05 AM   #4
TKCR
TKCR's Avatar
https://www.yourautotrim.com/auheclvifa.html
They have the sample cards that you can order, so you can pick out colors. I have all the cards on hand, because I do headliners for people every now and then. They are are few other places, but I like this place the best.
And this place. https://www.miamicorp.com/products/HEADLINING.aspx
I have used them too
Old 11-19-2018, 07:41 PM   #5
79 Silverado/454
79 Silverado/454's Avatar
Try www.smsautofabrics.com They can send you samples and dye it for you as well. I got mine from them and it turned out great !
1979 C-10 Silverado SWB 454/400 Turbo
1987 GMC Jimmy Sierra Classic
2015 GMC Sierra SLT Z71 (Cayenne Metallic)
2018 GMC Denali HD Duramax (Red Quartz)
79 Silverado/454 is offline   Reply With Quote
