C50 Cab Differences
Was wondering if anyone could tell me the differences on a cab from a C50 to a C10? From a quick glance it looks like the only thing that is really different is the front fenders/clip. Doors look the same to me. Hood is interchange-able? Thanks in advance.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e 1970 Chevrolet K5 Blazer - Project 1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4 1969 GMC Suburban - 5.3 LS, 4L60e |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: C50 Cab Differences
Cab mounts and trans jump is all I believe.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
60-66 Nut
![]() ![]() Join Date: Mar 2007
There is no trans 'hump' as it is just flat across. Then there is an extra brace across the lower part of the firewall on the engine side, plus I believe the '60-'66 medium duty cabs all have the '60-'62 front cab mounting location. Other than that, the cabs are basically the same.
Anyone ever put a C50 cab on a C10? I'd be interested to see how much work it would be
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Where the lower inner fender bracket is longer but is a bolt on item.
The additional brace as mentioned above. 100+ spotwelds to drill out. Hole beside the seat drivers side for the vent for the power brake booster. Look for a bolt in front transmission tunnel . You can cut out one from a light duty cab and bolt it in. Additional firewall hole on earlier for hydraulic clutch.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
![]() ![]() Join Date: Apr 2012
This is also used on a 10 series with power brakes.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
