11-19-2018, 10:43 PM | #1 |
Bracket & Brace Questions - Where do they go?
First pic is braces for power brake booster. Where do they go? I think the round bar bolts to the top bolt behind booster and the fire wall driver side. Can't figure out the other. Any pics or description on where it bolts?
Second pick is hood latch and brace that goes beneath it. Where does the third piece go? Basically an angle iron with 4 holes. Any help is much appreciated.
Zane's 71 Build |
11-19-2018, 11:26 PM | #2 |
Re: Bracket & Brace Questions - Where do they go?
Top bracket goes from drivers side stud on the front booster(the one the master cylinder bolts too) down to the fire wall, there is a threaded hole down by the steering column and floor support where it spot welds to the fire wall.
Second bracket goes from the back upper drivers side stud on the booster to the top bolt on the e-brake bracket where it bolts to the firewall. Last bracket goes on the drivers side inner fender. Last edited by sprint_9; 11-19-2018 at 11:36 PM. |
11-20-2018, 12:22 AM | #3 |
Here's some pics, not great but they might help:
11-20-2018, 01:38 AM | #4 |
Yes,
the bracket goes on the drivers side inner fender. |
11-20-2018, 07:26 AM | #5 |
Old member
Your last picture is the drivers side fender bracket as pictured above, hood release and the grille to radiator support piece at the hood release mounts to.
Its in between the front grille and support in the middle of the truck.
11-20-2018, 05:27 PM | #6 |
OH YEA, I remember now. Thanks.
I don't know how some guys tear vehicles down and put them back together years later. It has only been since July...
Zane's 71 Build |
11-20-2018, 05:26 PM | #7 |
I was close. Had the round bar deciphered.
Thank you very much!
Zane's 71 Build |
11-20-2018, 08:47 AM | #8 |
Inner fender brace should be turned around,large edge up.
