Old 11-20-2018, 12:03 AM   #1
jrpontiac
jrpontiac's Avatar
Rear brake drum rim interference 77 c10
I got some aftermarket wheel vintiques 62 series 15x8 steel rims from Jegs. 4.25 backspacing. The rear is a 1977 big 10. The rim is hitting the lip of the brake drum. Are the rear brakes on a Big 10 bigger than the normal c10. It is almost 1.5 inches short of going on all the way, basically the length of the lug nut. I took the drum off and it went right on. Anyone dealt with this before and what was the solution. The 15x6 steels I have been running fit right on.
1977 Chevy C10 SB, Turbo 5.3ls, TH400
jrpontiac is offline   Reply With Quote
Old 11-20-2018, 06:56 AM   #2
D13
D13's Avatar
Re: Rear brake drum rim interference 77 c10
Big 10 would have the big brake package. 11.15x2.75 vs 11x2 for base brakes. So yes, the drums are wider and deeper.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 11-20-2018, 11:35 AM   #3
Dads79GMC
Dads79GMC's Avatar
Is the wheel 10”? If so, Wheel Vintique probably reversed that wheel on you. If you still have the box, I bet it says REV on it. Thanks Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 11-22-2018, 10:50 PM   #4
andyh1956
My bud had a '78 or so Big 10 & we tried to install 8" Rallye wheels & they wouldn't fit.
andyh1956 is offline   Reply With Quote
Old 11-22-2018, 10:52 PM   #5
Dads79GMC
Dads79GMC's Avatar
I have one Heavy Half and a Big10 and 8" "factory" rally wheels fit on both. ???? Weird.
Old 11-22-2018, 10:54 PM   #6
jrpontiac
jrpontiac's Avatar
Im going to grab a rear drum off a non big 10 and see if that clears. If so ill have a decision to make.
1. 11x2 drum brake conversion.
2. Disc brake conversion. Only concern is..would the disc brakes clear?
