11-20-2018, 11:13 AM | #1 |
What are you using in-frame fuel tank swb???
I'm building a 67 SWB and want to find a tank that fits cleanly inside the frame. I am not using an in-tank fuel pump. Pictures would be great. Thanks
choctawchevyclassics |
11-20-2018, 03:50 PM | #2 |
Re: What are you using in-frame fuel tank swb???
boyd welding
07 GMC Sierra 2500 compound turbo' duramax 99 GMC Yukon solid axle swapped 67 Chevy c10 small window swb stepside supercharged ls6 70 Chevy c10 suburban 72 K5 Blazer 4wd |
11-21-2018, 08:11 AM | #3 |
Square body blazer, but no pics yet.
Do a search and you will get results, there’s a few out there.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
11-21-2018, 01:44 PM | #4 |
I'm using a fuel cell that mounts between the frame rails at the rear of the bed. Hopefully the picture attaches, but it shows where the fuel door is. May not be what you are looking for, but it is an option.
72 Chevy C10 383/465 69 Corvette convertible 454/650 |
11-21-2018, 03:23 PM | #5 |
Boyd and very happy with it
11-21-2018, 05:50 PM | #6 |
Boyds
Blazer Tank Wrangler Tank There are a lot of threads on each, the blazer tank option is the easiest but it hangs low. Wrangler tank is cheap but small. Boyd tank is super nice and made for this application but quite a bit more than the others.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
11-22-2018, 06:53 AM | #7 |
I am using a 71-72 mustang upgraded 20gallon fuel tank that fit between the rails and does not hang that low
11-22-2018, 07:35 AM | #8 |
Mine is a blazer tank
11-22-2018, 03:51 PM | #9 |
some use 69 Camaro tanks if you want the filler behind the license plate
11-23-2018, 11:50 AM | #10 |
Can you post a picture from the rear?
53’ GMC COE 55.2’ Chevy 3100 short step 67’ Dodge D200 Crew Cab 70’ Chevy C10 LWB |
11-23-2018, 02:02 PM | #11 |
16 gal . poly fuel cell.
Brad handshoe |
