Old 11-20-2018, 02:26 PM   #1
sweetk30
sweetk30's Avatar
Question few under dash wire problem / questions ?
body was donated from a 1987 c/r-10 v8/700r4 truck full loaded silverado .
wipers with OR with out delay box dont park at the bottom unless i turn them off there .
dash cluster out was testing for brake light switch problem . fixed it and then i went and held the brake lights on and pushed the 4 way switch and the plug for the gauge cluster started smoking NOT touching any metal . undid 4 way switch asap . ? ? ?
brake lights rear some times no left brake . bulb like new removed and tested 100% .
i am thinking turn signal/4way switch is junk . time for new . = brake light intermittent on/off left side and 4 way problem .
also no power windows or locks on both door switches . have not dug in yet .
what do you guys think ? i hate wiring diagnostics .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
