Help indentifiying my auto lock hubs on 73 K10
I'm not really sure what to call them so I didn't get much help using the search feature. I've got a 1973 K10 with auto locking hubs but they have 5 bolts not the typical 6 that I'm used to seeing. This is a weird truck, it's got a manual trans, but it's a 3 speed (no granny gear). Now I've come across this weird hub issue. Please enlighten me
1981 K10 (4.8 / 4L60E swap) 1982 C10 (5.3 / 4L80E swap) 1985 C20 Suburban (454 / 4L80E) Last edited by drmatera; 11-21-2018 at 12:17 PM. |
Re: Help indentifiying my auto lock hubs on 73 K10
ok, so in searching further it appears the auto hubs from 81-87 are 5 screw. So do I have a corporate axle up front?
1981 K10 (4.8 / 4L60E swap) 1982 C10 (5.3 / 4L80E swap) 1985 C20 Suburban (454 / 4L80E) |
i think you got your self a mutt boy
![]() but yes there from a 81-up body group . they can fi the older dana 44 axle tho . so make sure you know what style axles you have before ordering parts . post up a pic of the front and rear pumkins .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Hahaha. Not surprising
yep dana 44 front and gm 12 bolt rear .
good to know thank you. So one more question, when I buy manual hubs do I need the conversion nut kit? I guess I also need to find out which transfer case I have. I'll post pics shortly
Ok, not sure if you can tell by these pics what t case I have.
i was just talking about that trans and t-case combo in another thread in the 4x4 section today .
thats a car 4 speed hooked to a np205 part time t-case . that combo is rare . i have seen a few online and 1 in person . the np205 is a gear to gear part time case . solid as a rock units . as for the nut conversion i swapped one set out years ago and didnt need it . so best to pull one off and if its the reg old 4 tab nut/washer/nut combo then your golden with just a set of lockouts . i my self do NOT run warn hubs or most others . the way there designed if they fail they fail open / unlocked . i prefer the old original spicer hubs or the newer yukon hubs that are a updated / combined best of both style spicer hubs in 1 best package . there a little more $ but great stuff .
Thanks for all the great info.
no problem
The standard transmission in your 73 K10 would be a 3-speed steering column shift. I think someone converted your column shift to a floor shift. Pretty common back in the day. The only engine choices were a 250 six cylinder and the 350 V8.
#12 | |
Moderator
![]() Join Date: Oct 2008
AFAIK They only used the 4 speed in the automobiles.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#13 |
Here is a pic of the VIN. I guess this cab could have been from another chassis, so who knows
#14 |
Hey that's cool!
I only ever saw the 3 spds in Blazers, not pickups. But they had Dana 20s hooked to them. Does the steering column still have provisions for a shift lever & linkages? |
#15 |
yes the column does still have the remains of the "3 on the tree".
#16 |
Moderator
I learned to drive on a column shift 1950's pickup truck and a 1949 Chevrolet Deluxe with the same.
IMHO the 40's & 50's shift mechanisms were more robust than the ones from the 70's. The column shift mechanism isn't that difficult to learn. It's not unreliable if it's adjusted properly with fresh shift rod bushings and it's a cool theft deterrent.
| Bookmarks |
