Old 11-22-2018, 01:16 PM   #1
scott123
LS semi-swap
I have a high mileage Tahoe. I have a '71 K5 Blazer chassis.
I am going to put the 2001 Tahoe on the 71 chassis. I am going to keep the TH350/NP205 and use the 5.3.
A buddy of mine did one in a 72 2WD. There were some frame mods for the A/C compressor and I think something for the oil pan clearing.
What issues will I run into by using the TH350? ....all other wiring would remain the same.
S
scott123 is offline   Reply With Quote
Old 11-22-2018, 04:16 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: LS semi-swap
You'll need the spaced flexplate to put a turbo behind a LS..and the t/c bolts need reamed out..other wise ,no issues in connecting the two..
I had to use a vett oil pan on mine to clear the front axle...
Does the Tahoe and blazer wheel base match up?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-22-2018, 04:55 PM   #3
scott123
Re: LS semi-swap
I have not measured either yet. I'm sure they are close but I will end up cutting the frame.
It is funny, cutting the frame bothers me less than that one wire hanging around that puts the whammy on everything. LOL
The t/c bolts...reamed for what?
Old 11-22-2018, 05:16 PM   #4
mongocanfly
Post Whore
Re: LS semi-swap
Turbo converter bolt patterns don't match LS flex plate..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-22-2018, 05:20 PM   #5
mongocanfly
Post Whore
Re: LS semi-swap
https://ls1tech.com/forums/conversio...350-5-3-a.html
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-23-2018, 01:49 AM   #6
jrpontiac
jrpontiac's Avatar
Re: LS semi-swap
I hooked up my 5.3 to a th400 last week. I used this flexplate, it was $56 on Amazon. No spacer needed. ATP Automotive Flexplate z-270. Torque conv. Bolts matched up.
1977 Chevy C10 SB, Turbo 5.3ls, TH400
jrpontiac is offline   Reply With Quote
Old 11-23-2018, 03:25 AM   #7
ls1nova71
ls1nova71's Avatar
Re: LS semi-swap
S
You are going to put a 2001 Tahoe body on a 1971 Blazer frame? I have to ask, why? Seems like a big step backwards and a lot of money and work to get there.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-23-2018, 08:34 AM   #8
scott123
Re: LS semi-swap
Sort of like every other project on here....why? not to smart off but because I want to....
Years back I put a 85 S-10 on a 72 K5 chassis. 383 with 350/205 with 4.11's on 35's. It was a neat truck and a **** load of fun.
It will not be all that much money as far as LS or conversion projects go.
I have every thing here with the exception of the flex plate and motor mounts.
The Tahoe was long paid for...the K-5 chassis has a 4" lift, 4.11 rear ends, with a 350/205 that was driving when I parted it out. The body is already gone to greener pastures.
This would be my first project with a LS motor but since it will land back in its original home it can't be as big a deal as having to work with harnesses...etc..etc..
S
Old 11-23-2018, 12:22 PM   #9
Jstock85
Re: LS semi-swap
Hooked up a 4.8 to a th350 this past summer. I used no spacer just the centering ring and yeah you'll need to ream out the flex plate bolt holes about 1/4". I also had to connect a VSS from Dakota digital to the speedo cable so the pcm would know how fast the truck is moving. The trans fluid tube was bit of a problem because of the missing bolt hole. you can get a bracket on amazon cheap that bolts to the back of cylinder head to hold the tube in place. and there is a place on the pass side of the intake to connect the vacuum line to.
Sounds like a lot but everything fell into place one the motor was put in.
Jstock85 is offline   Reply With Quote
