Old 11-22-2018, 02:52 PM   #1
Lee H
Lee H's Avatar
1972 Hood damage and question
OK so I had a little hood mishap. The fan blade let go, I have 4 of the five blades, they are pretty crumpled up. Part of the fan mounting flange is still under the bolts against the fan clutch. This is a 90s truck serpentine setup. I’ve begun my search for parts and a replacement hood. The mechanicals are going to be easy, fan, shroud, radiator and heater hoses, trans cooler lines, battery should cover most of it. I’ll need to splice together the wiring harness. Looks like my RnD fabrication radiator is OK.
I’m going to start looking for an original equipment hood. My question is, are the reproduction hoods any good these days? I know they have not been good in the past. Is anyone making a great repop?? Second question for the factory restorers, did the underside of the hood come body color or black, I painted mine black then I did the frame off, will go with factory this time.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 11-22-2018, 03:12 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: 1972 Hood damage and question
All I can say is damn that sucks. I’m glad no one was hurt.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 11-22-2018, 03:41 PM   #3
RustyBucket
RustyBucket's Avatar
Were you just cruising merrily along when this happened? I think about this when I see people grab the throttle linkage with the hood up and rev the crap out of an engine.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 11-22-2018, 03:41 PM   #4
toolboxchev
Hoods are very easy to find OEM...they are a dime a dozen, everyone saves them and they tend to hold up over time verses a fender.
toolboxchev is offline   Reply With Quote
Old 11-22-2018, 03:57 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Oh man that looks bad, could have been so much worse though! Curious, do you know if the fan was a GM original, or aftermarket?
To your second question, the underside of my hood ('72 K20) is the original black. Not as shiny as yours though, maybe flat but probably closer to satin (when new). Yours looks like it might be semi-gloss.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 11-22-2018, 04:11 PM   #6
HO455
Post Whore
HO455's Avatar
Yikes!!!! I happen to know that will get your attention. In high school I had a 47 International KB5. One day headed off to the woods the fan blade broke off of the mount.(The water pump bearing was a bit loose). BAM! I had a 1" slit in the hood. Immediately BANG, under the truck. I look in the mirror to see what just fell off and I see the fan blade spinning up out of sight never to be found. Somehow the fan didn't touch anything but the hood and the pavement. The upside of not having a shroud to contain the fan.
Hope your radiator is good. Here is a link to a under hood paint discussion from the past.
http://67-72chevytrucks.com/vboard/s...d.php?t=352569
RIP Bob Parks.
Old 11-22-2018, 04:20 PM   #7
CG
BlahBlahBlah
So you need misc engine accessory items, a hood, and some new shorts.
An OEM hood should be an easy find.
Old 11-22-2018, 04:34 PM   #8
Lee H
Lee H's Avatar
Yes original GM, I bought it new when I installed the serpentine system.
Old 11-22-2018, 04:35 PM   #9
Lee H
Lee H's Avatar
Yikes!!!! I happen to know that will get your attention. In high school I had a 47 International KB5. On day headed off to the woods the fan blade broke off of the mount.(The water pump bearing was a bit loose). BAM! I had a 1" slit in the hood. Immediately BANG, under the truck. I look in the mirror to see what just fell off and I see the fan blade spinning up out of sight never to be found. Somehow the fan didn't touch anything but the hood and the pavement. The upside of not having a shroud to contain the fan.
Thanks for the thread. Looks like black it is.
Old 11-22-2018, 09:12 PM   #10
Sparky dave
Holy crap that’s the last time I lean over the fan reving the engine!
Sparky dave is offline   Reply With Quote
Old 11-22-2018, 11:02 PM   #11
Husker
Husker's Avatar
Ouch. Good noone was injured.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
