Old 11-23-2018, 08:20 PM   #1
Jurassic-1
Jurassic-1's Avatar
GMC ? Chevrolet 235 difference
Does anyone know if a 1954-1955 1st series 235 is longer in a GMC than in a Chevrolet?
Jurassic-1 is offline   Reply With Quote
Old 11-23-2018, 09:58 PM   #2
joedoh
joedoh's Avatar
Re: GMC ? Chevrolet 235 difference
answering your exact question, a chevrolet 235 will be the same length no matter what truck its installed in :P
but jokes aside, gmc engines are completely different than chevrolets, and yes they are about an inch longer. gmc didnt make a 235, they made a 228, 248, and 270. in a half ton 54-55.1 it should be a 248. you can find the engine size on the flat pad next to the distributor, the first 3 numbers will be the engine size.
gmc engines were full pressure oilers (so were the 235 chevys of 54-55 though) and made more torque.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 11-23-2018, 11:27 PM   #3
whitedog76
GMC I6 engines are actually longer than the Chevy.
On the early trucks there was a dip in the front crossmember on the GMCs so the front pulley would clear the radiator support.
whitedog76 is offline   Reply With Quote
Old 11-24-2018, 11:41 AM   #4
Jurassic-1
Jurassic-1's Avatar
Thank You for the info. Seems there were a lot of differences in those days. Today just looks.
Old 11-24-2018, 02:15 PM   #5
mr48chev
mr48chev's Avatar
Yep, the old timers (way older than me) still will tell you that the GMC trucks from those years were built a lot more heavy duty than a Chevy was. Frame is exactly the same except for the front crossmember but I have probably had a hundred guys who would now be in their 90's tell me that the GMC trucks were built more heavy duty.
Back when I was 19 I put a 248 GMC six in a 50 Chevy hardtop and that was quite a challenge. It would have been a lot easier to replace the broken piston in the 216 and do a ring and valve job.
My ongoing truck projects:
Old 11-24-2018, 03:57 PM   #6
mr48chev
mr48chev's Avatar
The top photo is (or should be) a member's truck showing the Jag XJ suspension install that shows the Chevy front crossmember
The other photo is a shot of the front of my GMC 1/2 longbed frame that I am going to use under my 48 in the rebuild. I'm using it so I can stretch the cab 9-1/4 inches and have an unmodified frame.
You can see the way the front crossmember is dipped way down where the core support sits.
Old 11-25-2018, 12:04 AM   #7
Jurassic-1
Jurassic-1's Avatar
I have several projects of my own. I have a friend who has this 54-55 GMC . He may need a rebuild able GMC engine. I passed the information everyone passed on about the size. Any leads on another engine would be appreciated. I have a 1955 1St series 3100 Chevrolet 5 window in my collection. It has 67000 actual miles on it. It has a hydro attic trans in it. It runs great.
Old 11-25-2018, 12:23 AM   #8
whitedog76
The Chevy engine will fit a GMC, you just need to keep the GMC radiator support.
The Chevy car engines have the longer water pump, which causes some clearance issues, but since yours is from a 54-55 1st series, shouldn’t be an issue.
Old 11-27-2018, 09:06 AM   #9
whateverpratt
I think the reason the old timers talk about how the GMC trucks were more heavy duty must be that the GMC range went beyond the 2 ton weight rating that chevy stopped at until the '60's or so when chevy started making some really heavy trucks.
'66 c10 rust bucket, 350 (pulled and sold, now waiting on 4bt install) nv4500 stock bellhousing, '85 c30 front suspension and 3/4 rear coils with 4.10 H072 rear axle
NV4500 install http://67-72chevytrucks.com/vboard/s....php?p=6488778
Suspension update http://67-72chevytrucks.com/vboard/s....php?p=8236775
whateverpratt is offline   Reply With Quote
