Old 11-23-2018, 10:11 PM   #1
rechinca
rechinca's Avatar
Ram Horn Manifold Differences
As I am shopping for a replacement rams horn manifold for my truck, I have a questions I really can't find good answers for. The current LH manifold in my '71 is a 3989055 and I am having a hard time finding a replacement with the same number. What I do find are a lot of 3932473 manifolds. Both are the angled back dump, but I can not seem to find any more info out there.
From what I have been able to determine is:
3989055 - 69-72 307, 350 & 400 LH
3932473 - 69-70 327, 350 & 400 LH Passenger 235, 250, 255, 265 & 300 HP 2.0" Outlet
So is there any difference, and if there is, what is the difference?
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 11-23-2018, 11:01 PM   #2
PepperTreeGarage
PepperTreeGarage's Avatar
Re: Ram Horn Manifold Differences
Maybe try here:
https://www.speedwaymotors.com/shop/...SAAEgLIGfD_BwE
PepperTreeGarage is offline   Reply With Quote
Old 11-24-2018, 04:06 AM   #3
rechinca
rechinca's Avatar
I have looked at the page before, but it deals mainly with aftermarket straight dump rams horn manifolds. The two numbers I am trying to decipher were for the 45*-ish rear swept dump ones. Although those too are available aftermarket, I was trying to locate a good GM one and found the two different part numbers. The one designated for the cats is far more readily available while the 3989055 for the trucks is not. And for all I can tell so far there is no real difference other than that number cast on the side. I am not doing a nut and bolt resto, but would like to find the same casting number all the same. I appreciate the link to Speedway though!
Old 11-24-2018, 08:10 AM   #4
35boulder
35boulder's Avatar
Try placing a WTB in the parts forum. Should be able to locate one there. Good luck!
35boulder is offline   Reply With Quote
Old 11-24-2018, 03:52 PM   #5
rechinca
rechinca's Avatar
Already placed the ad a couple of weeks ago. Only one response with the Car style part number.
Still have not gotten to the bottom of the question: what is the difference between the two?
Old 11-29-2018, 05:27 AM   #6
mike16
maybe one is plumbed for A.I.R.
mike16 is offline   Reply With Quote
Old 11-29-2018, 10:07 AM   #7
kenn
Hello I've been having trouble finding the correct ones for my 72 for years and all I want is stock.
kenn is offline   Reply With Quote
Old 12-04-2018, 05:26 AM   #8
72c10porter
I may have what you need....ill check the garage when it is more daylight
Would these be the same as the factory ones I took off my 72 c10 350?
Edit:No dice yet
Sorry buddy
To the initial question yes there are a few minor changes the main reason for the changes is clearance with shifting and clutching components im going to guess the only way your going to find what your looking for is if you stumble across another 71 c10 /w 350 /w 3spd ...even though mine is 4on floor i Had this problem when buying headers( had to make some are there would be no interference would clutch)
72c10porter is offline   Reply With Quote
Old 12-04-2018, 07:32 AM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Ram Horn Manifold Differences
Some of the ram horns had provisions for the AC mounts and alternator mounts on the end of them facing forward. That is the only differences I know of.
The trucks didn't have these.
Well the ones I've used didn't.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
