Old 11-25-2018, 08:17 PM   #1
lemoncolt64
Inner rockers
Good evening, i have read through the fact sections on rockers and patch panels and done some searching, however i am unable to find quite what i am looking for. I bought some inner rockers from brothers. I was hoping someone would have some pics or threads giving me and idea how I can do mine.
truck is a 1963 C10 swb stepside
lemoncolt64 is offline   Reply With Quote
Old 11-25-2018, 09:34 PM   #2
joesscamaro
Re: Inner rockers
I have no pictures, but I’ve replaced mine in the past. What exactly is your question, I’m sure someone will be able to give sound advice if I’m not able.
joesscamaro is offline   Reply With Quote
Old 11-26-2018, 05:25 PM   #3
jdl71
jdl71's Avatar
Re: Inner rockers
I'm pretty sure there are several threads on this if you look through the FAQ section. Even though they might not be just the inner rockers it should have that covered in one of them.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 11-26-2018, 05:44 PM   #4
lemoncolt64
Re: Inner rockers
Thank you all for the fast responses, i will continue reading through the faq sections to see i can stumble across this.
Old 11-26-2018, 11:01 PM   #5
rws1012
Re: Inner rockers
There is a guy on You tube that has redone a 63. Think his name is Gibson and he does really good videos. Check him out
rws1012 is offline   Reply With Quote
Old 12-01-2018, 10:37 AM   #6
LT1 Burb
LT1 Burb's Avatar
Re: Inner rockers
Here is a couple pictures of mine, you will most likely need the bottom of the A pillars as well, just measure twice and cut once. I ended up using NOS rockers because I hated the way the repops fit.
LT1 Burb is offline   Reply With Quote
Old 12-02-2018, 12:11 AM   #7
Captainfab
60-66 Nut
Re: Inner rockers
I prefer to use this piece on the outer area of the cab floor.
https://www.topbananaparts.com/drive...r-section.html
