Old 11-26-2018, 08:17 PM   #1
Northwest Outlaw
Northwest Outlaw's Avatar
BIG truck fenders on pickups?
I know that Ive seen pic on the forum beofre but can't seem to find any right now. Looking for front fenders from the Medium/Heavy Duty trucks on a pickup. thanks
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline   Reply With Quote
Old 11-26-2018, 09:14 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: BIG truck fenders on pickups?
They are about 6-8” wider than the stock c10 fenders so unless you have a wide stance, it wouldn’t be very appealing imo. To each his own tho
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-26-2018, 11:03 PM   #3
jocko
jocko's Avatar
Hmm...
Old 11-28-2018, 12:35 PM   #4
350TacoZilla
Few things to point out is you have to run the big truck grill valance and possibly mod core support. All the ones I have seen just use the entire front clip from medium duty or just start with medium duty truck and put a bed on it. Also there are 2 different size fenders for big trucks, I cant remember exacts but its something like 4-5" flare or 2". Here are 2 pics I have showing different ones, also note they are both 64-66 cabs. I have seen both narrow and wide on both 60-63 & 64-66 cab styles so not sure if the cut off is something obvious like C50 and down got one and c60 and up got other or if it was a different option that any GVW truck could have them.
I have been looking at them for awhile and plan to try and cut up some junked sets to make flares for the front and rear of my truck so they match. I even thought of getting them to fit and then using them as a mold to make some fiberglass or plastic flares that I can bolt on instead of weld on with body work involved. (I still need to find few more in hopes of using decent sections from them.)
350TacoZilla is offline   Reply With Quote
Old 12-11-2018, 02:28 PM   #5
forestb
forestb's Avatar
I have always thought it would be really cool to add that grill surround to a c10 using the c10 fender openings. I think it would be the only good way to add a role pan to the front. a while back there was a guy on here that was trying to do it but I don't know if he ever finished. It would be even better if you could shorten the front using one of those short hoods.
forestb is offline   Reply With Quote
Old 12-11-2018, 07:57 PM   #6
350TacoZilla
Just to point out the trucks I posted are the standard length hood trucks, the LCF short hood trucks have completely different fenders\core support. I also had a brief thought of using the short hood size with modded C-10 fenders and then maybe a 4.5-5ft stepside bed to try and balance out the look.
I'm personally not as big of a fan of the grille valance area on the big trucks and want to keep my stock light duty front end. I just want to benefit from the flares that match the lines of the truck well vs a set of aftermarket rubber flares.
