Auto conversion - clutch block off and shifter
I will be swapping my i6/3ott for a 5.3/4l60e combo. What is everyone doing to block off the hole for the clutch linkage? How about the auto shifter - better to source an auto column or do a shifter in the floor?
Moderator
![]() ![]() Join Date: Aug 2011
Re: Auto conversion - clutch block off and shifter
I wonder if it's the same size as the 67 and up holes? - https://www.classicparts.com/1967-72...info/90%2D542/
and https://www.classicindustries.com/product/152862.html I could swear I saw a steel push in plug somewhere...
![]() Join Date: Jan 2011
I am running the Lokar bench seat shifter in my 66 and it looks right at home in it. I cut out a piece of steel to fill the hole in mine and put it in with a couple of screws and seam sealer.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#4 | |
![]() Join Date: Sep 2002
I welded the linkage together so the shifter would no longer move back and forth, only up and down. Then I made up a rod and lever for the tranny end and just used the three speed column as an auto column with no indicator.
Moderator
I once rode a pony.
