11-27-2018, 09:57 PM | #1 |
Wire routing for overhead accessories?
Need some help on routing wires inside roof. My Custom Deluxe is bare bones and I need to run power in the roof for the running lights, mirror map lights and rear courtesy lamp. Is it possible to run wire down the A-Pillar or across the roof and down the rear pillar? I pulled the visor tonight and could only poke wire a limited distance. I'm thinking the metal is folded 90 degrees at the seams where the panels butt together. How did the factory do it?
11-27-2018, 10:00 PM | #2 |
Re: Wire routing for overhead accessories?
stock cab 5 light outside does go up a-piller and across .
rear cab light in or out side versions up b-piller and across .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
11-27-2018, 10:11 PM | #3 | |
The front might be tricky. I couldn't find a passage at the top inside the pillar to fish it down. I'll give it another shot tommorow. |
11-27-2018, 10:16 PM | #4 |
Post Whore
Yep...clearance lights in a pillar.....cab lights up rear cab corner..
11-28-2018, 11:05 AM | #5 |
Use a stiffer wire.
Maybe a #12 solid copper wire and bend a close loop in the end.The small loop makes it easier for it to get past obstructions in the pillar. Mike. |
11-28-2018, 11:24 AM | #6 |
and if it was me and the wire is that close to the main ground bar on the driver side by the brake pedal run a dedicated ground wire also .
11-29-2018, 10:27 AM | #7 |
Spent a good hour last night trying to get a piece of solid core wire thru the A-Pillar. Ain't happening! Doesn't matter if I go from the bottom up or the top down, it's not going.
However, it's a moot point as I was able to get it fairly easy from the d/s front roof above the door and down the B-Pillar. Either way, I now have power where I need it. |
