Old 11-27-2018, 10:13 PM   #1
rob7233
97 C1500 Coil Spring Selection Help
I am in the process of selecting parts for a total front end rebuild for my 1997 C1500 - GMC Sierra, Reg sized Cab w/5.7L 350 engine plus AC. Also, since I often pull a 4500 lb trailer with it, I have added HD rear leaf springs and Load Lifter 5000 air bags to help.
A VIN search gave me the original Coil Spring OEM parts# 15528980 but gave no specs except (4685 lbs) to which I was told by a dealer parts guy "they measured them different back then" ?? Otherwise, I searched online and have found no direct recommended interchange replacement.
@ Rockauto.com the 2 variable coil spring options I'm considering are:
1) ACDelco Professional 45H1057 (Load Rate=2170.00) The relaxed and compressed lengths between the two choices are only 1/4" from each other.
2) Moog CC650 (Load-lbs 2325.00 it also gives the Spring Rate=1025.00)
I've been told either should be fine but I was hoping someone here might have some direct experience or offer information that could help me make a comfortable final decision. Thanks in advance for your help...
rob7233 is offline   Reply With Quote
