Old 11-28-2018, 03:23 PM   #1
weider1717
Where can I get 1.5-2" zero rates?
Since I am staying very mild with a 2" lift I thought I would be jut as happy probably with 1.5-2" pro rates to just fit 33's better.
Just a thought, thanks
weider1717 is offline   Reply With Quote
Old 11-28-2018, 03:44 PM   #2
SilverMiner
SilverMiner's Avatar
Re: Where can I get 1.5-2" zero rates?
The good folks at Offroad Design are where you want to go for all of your 4x4 squarebody needs. They only sell 1" zero rates though - I'm not aware of anybody making taller ones.
I did something similar to what you're proposing - I put a 2" lift block in the rear and 1" zero rates in the front of my 1980 Suburban and kept the original springs. I'm running 255/85/16 tires and the clearance and stance are just what I was after.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 11-28-2018, 03:52 PM   #3
sweetk30
sweetk30's Avatar
general rule its just not good to do more than a 1" bolt in block on the front . if you need more than that just get springs .
if your springs are orignal then even if it was say a 1991 k5 blazer there almost 30 years old by now .
a good brand 2" lift kit with rear blocks will not be hard riding . and if you do do this get new bushings for the frame shackle mount position . they will 90% or more likly be junk by now .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-28-2018, 03:55 PM   #4
95 S_Trucker
95 S_Trucker's Avatar
And in some states(PA included) lift blocks of any size in the front are illegal.
95 S_Trucker is offline   Reply With Quote
Old 11-28-2018, 04:17 PM   #5
sweetk30
sweetk30's Avatar
even a bolt in zero rate ?
