Old 11-29-2018, 12:43 AM   #1
First c10
First c10's Avatar
New to me 6.0
Hey guys. I was at my local wrecking yard and found a 2001 Yukon Denali
I bought the complete package; motor, trans 4l60e, uncut harness and pcm, fuse box, pedal, intake extra.
After the motor was pulled the transmission was rebuilt not to long again as it was clean and silver.
I am not sure but is there a tac module? If so what does it look like and where is it located? I want to make sure I get it.
Oh and I got it for 600$ and they removed it. 151k
Also what should I inspect on this package?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 11-29-2018, 01:19 AM   #2
ls1nova71
ls1nova71's Avatar
Re: New to me 6.0
If its DBW, there will be a TAC module to the left of the brake booster (to the right if you are standing at the front of the truck) it will be all plastic on an '01. You will need to get an '03-'04 TAC to pedal harness since in '01 and '02 that harness is part of the body harness and almost impossible to remove, unless you want to just cut the two ends and splice them back together.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-29-2018, 01:54 AM   #3
First c10
First c10's Avatar
Re: New to me 6.0
I had to cut the pigtail inside he truck to the gas pedal.
I cut the black plastic box that was under the dash directly under the steering wheel.
I didn’t see anything left next RO the brake booster.
How big is it? The black plastic box I got was about 6x5” with 2 plugs. I thought it was the body control mod.
GO GO!!!
Old 11-29-2018, 09:51 AM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
Re: New to me 6.0
Like this...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-29-2018, 11:45 AM   #5
First c10
First c10's Avatar
Re: New to me 6.0
Thank you Greg,
Is that the 03-04 style? that pigtail looks to be what ls1nova71 described?
I will post a picture of what I got tonight. I may have to go back and look as I didn't see anything in the engine compartment that is why i had to get under the dash.
GO GO!!!
Old 11-29-2018, 12:01 PM   #6
ls1nova71
ls1nova71's Avatar
Re: New to me 6.0
Yeah, that one that Mongo posted is the 2003-up style. The 2001-2 is all plastic. This is mine, pay no attention to the broken off ear of it, that's what happens when you do something stupid... LOL! The black box you got if it was right u der the column is the BCM, they can be made to do fun things!
Old 11-29-2018, 12:14 PM   #7
mongocanfly
Post Whore
Re: New to me 6.0
Good to know...I was unaware of the differences....mine is a 03 model
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-29-2018, 12:58 PM   #8
First c10
First c10's Avatar
Re: New to me 6.0
Thank you guys.
Ls1- was it mounted to the inter fender?
The front clip was removed and sitting off to the side so maybe that's why I didn’t see it.
GO GO!!!
Old 11-29-2018, 06:34 PM   #9
ls1nova71
ls1nova71's Avatar
Re: New to me 6.0
No its definitely mounted on the firewall. There is a plastic bracket that is bolted on and then the TAC module just clips in it. Maybe someone already got it?
Old 11-29-2018, 07:16 PM   #10
First c10
First c10's Avatar
Re: New to me 6.0
The motor was pulled for me but I did remove the pedal and bcm.
I looked at the harness and found this box attached I didn’t see before. I am sure this is it. Does yours have 2 plug ins?
Second picture is the BCM I pulled from under the dash.
GO GO!!!
Old 11-29-2018, 10:59 PM   #11
ls1nova71
ls1nova71's Avatar
Re: New to me 6.0
Yep that's the TAC and the one with 3 plugs is the BCM. Mine has 2 plugs but where its mounted it was hard to get a pic of them.
Old 11-30-2018, 12:28 AM   #12
First c10
First c10's Avatar
Re: New to me 6.0
So I am guessing I need to go back and get the other plug for the TAC module.
GO GO!!!
Old 11-30-2018, 06:28 PM   #13
ls1nova71
ls1nova71's Avatar
Re: New to me 6.0
Well only if you plan on ever giving it any throttle, it will idle just fine without it!
Old 12-02-2018, 11:08 PM   #14
First c10
First c10's Avatar
Re: New to me 6.0
Picked up the plug and as much wire I could get. So now I can rev above idle. Lol
Thank you guys
GO GO!!!
