Old 11-29-2018, 02:26 AM   #1
Thanos
Thanos's Avatar
8.1 engine mounts?
I removed my old 454 from my 72 GMC yet the engine mounts on the 8.1 are vastly different. I have found where people somehow used the old mounts with the 8100 vortec yet the engine mount bolt pattern on the block looks different for some reason.
Anybody know any really good engine mounts for a conversion like this? Possibly poly type? I can't find much info on the 8.1 .
Thanos is offline   Reply With Quote
Old 11-29-2018, 07:30 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: 8.1 engine mounts?
You might try member DirtyLarry. He has a 8.1 in his square body, which shouldn't be that hard to adapt to fit your needs.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-29-2018, 11:37 AM   #3
Thanos
Thanos's Avatar
Yea would like to contact him, he has a picture of the old mounts on a 8.1 yet the mounting holes doesn't look the same as mine. I have a 04-06 model though, I wouldn't think that would change anything.
Old 11-29-2018, 12:21 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Dirty Larry sez:
"The 8100 block has the same motor mount points as early small and big block Chevy's. Even the heads shared the same exhaust flange pattern. I was able to use a set of hedders from Dynomax and they bolted right up! A Turbo 400 bolted right up the 8100 and the torque converted bolted right up to the stock 8100 flex plate. Even a stock starter for a 1977 Chevy small block bolted right up, cranks over fine."
I'm not sure if they changed anything in the later blocks or not but I wouldn't think so.
I wouldn't use the poly mounts, they transfer too much vibration. The regular '72 BB clam shell mounts would be the best if you can find some.
LockDoc
Leon
Old 11-29-2018, 12:24 PM   #5
davischevy
davischevy's Avatar
Not my thread but Thanks Leon.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 11-29-2018, 12:35 PM   #6
LockDoc
LockDoc's Avatar
Hey, where's the smiley...... I didn't say "Other Larry" I said "Dirty Larry"....
LockDoc
Leon
Old 11-29-2018, 01:03 PM   #7
68Gold/white
The 8100's were made for such a short period of time, unlikely that the block mounts were changed...just a thought...
now if we were working on a ford.......
68Gold/white is offline   Reply With Quote
Old 11-29-2018, 01:51 PM   #8
Thanos
Thanos's Avatar
Checked again found out what the deal was, going to have to grind one down to match the others. Thanks for the input fellas!
Old 11-30-2018, 10:25 PM   #9
mingoman
I bought the inserts Larry suggests for the clamshell mounts. We'll see how they work out.
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 12-01-2018, 12:58 AM   #10
LockDoc
LockDoc's Avatar
Let us know.
LockDoc
Leon
Old 12-01-2018, 01:08 AM   #11
davischevy
davischevy's Avatar
LockDoc
I didn't even noticed the Larry thing the first time Leon.
There are so many of us we have to add a tag.
other Larry
Old 12-01-2018, 02:05 PM   #12
mingoman
Here are the ones I bought, 3.1116R.
76/77/78 Cheyenne
Old 12-02-2018, 05:05 PM   #13
Thanos
Thanos's Avatar
Are these the BBC version? Because I was looking at the 3.1121R they list them for BBC however it almost seems like they are all alike.
Old 12-03-2018, 11:32 AM   #14
mingoman
I thought they were, but I may have read it wrong. My truck has an L29 454 now and I plan on using the clamshells that came with it.
76/77/78 Cheyenne
