Floor carpet question.
I'm about to start with the interior now. I can't remember when I tore everything out, it was like 2 years ago now. So just to verify the order; after I apply dynamat on the floor, then goes the carpet, seatbelts and finally the bench, correct? Also, do I have to take the gas tank out for the carpet? This is my first build, excuse the noob inquiries.
Thanks! |
#2 | |
Old member
![]() Quote:
The hardest thing for me is cutting the holes for everything through the carpet. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Floor carpet question.
Take your time. Don't get in a hurry and start rushing to get to the end... -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() Join Date: Dec 2013
I saw a suggestion on here to use a soldering iron to burn the holes in the carpet. I tried it and worked really well. Just poke the hot iron up from underneath the truck. Good Luck!
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
Old member
Making the holes isn't the problem. It's making them in the right locations for everything that ha to be mounted.
#6 | |
And thank you all for confirming my doubts. Starting on it tomorrow. |
#7 | |
Like I said its easy
Brian Ritter |
Progress!
![]() Join Date: Sep 2014
Auroch,
How much square footage of product did you use? I can see you have the door skins lined also. I'm trying to determine how much to order. Nice job ![]() Sam Last edited by samkost; 12-01-2018 at 11:25 PM. |
#10 | |
Old member
![]() Quote:
That's easier said than done sir. I haven't said I didn't know how I said it's the hardest part. You cut the carpet 1" off and well it just ant that easy! For me anyway. ![]()
The Older Generation
Also be very careful when you screw the bolts in. If you catch a yarn in the threads of the bolt it will wrap around the bolt and pull the row of yarn out all the way across the carpet. Edit: That only happens with the loop style carpet, not the cut pile. LockDoc
I got the Dynamat xtreme 36 sq ft bulk pack, it contains 9 large sheets. Highly recommend getting the rubber roller tool. It was enough for the entire floor and firewall as you can see on the pic; ended up with a sheet and a half left over which I used inside the doors. I also got one roll of Dynamat finishing tape just to make it look perfectly even on the edges, not necessary, but looks nice.
#13 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I bought ACC carpet with the mass back, should I still use Dynamat ?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#14 | |
#15 |
You said you have a difficult time locating the holes! That's how you locate the hole with ease
Brian Ritter |
#16 |
That depends on you, your current setup should be fine. Are you still getting a lot of road noise? I’d say combine the two if you want it to be quieter still. I will say, if you’re running a high end sound system, Dynamat does improve on the acoustics of your cab, not to mention bass control, kills the cab rattle.
