Holley woes
I have a holley 1850 on my 81 and twice now it has gone into mass flooding once from the back bowls and once from the front I turned the float all the way down to stop it both times and then readjusted. I have had alot of holley carbs and never had this type of problem the filter looks clean going in I have not pulled the bowls yet but maybe this weekend I will get to that. I guess my question is what would you guys start with (other than a new carb ) ?
5-7 dropped 87 CC Dually
Sounds like you got dirt in it. Give it a qwik rebiuld.
I rather be in my 77 Sanger Picklefork Jet Hydro! |
Did the rebuild not alot of dirt but some so hopefully that was it but it wont be going anywhere anytime soon tranny went out today while I was test driving the carb.
Thanks Steve |
Oh,you can't buy that new
![]() Join Date: Apr 2000
your not running any type of hi-po fuel pump are ya ?
the flaots could also be heavy- as in filled with fuel-as in leaking. the styrofill one(black foam) get saturated and get heavy. Most older 1850's are brass but they can leak also. Just a few of the many troubles it might be .
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() 84,C10 SWB-Yella,stock 86 K10 SWB-Red, hopped up 305,4/S LOTS of Cummins trucks. |
