class 5 hitch
hello all,
I was going to upgrade my hitch on my v2500 to a class 5. I occasionally will need to tow a track loader. It and the trailer will weigh ~12k. Is there any reason a hitch for a 1980s C/K3500 would not fit? How different are the frames? I am using k3500 springs on my v2500 and they were bolted right in. https://www.etrailer.com/Trailer-Hit...cc-onlyreviews https://www.etrailer.com/p-BWHDRH251...model=Suburban |
Re: class 5 hitch
12k is a BIG load buddy .
rear end of the frame is basically the same on 1/2-1ton trucks . if suburban or blazer thats a whole different frame setup not the same end rail style . yes you put bigger springs in your 3/4 ton but the frame is still 3/4 ton size . also the brakes are prob a lot smaller over the 1ton rears and the front for sure are smaller . last better check the local laws on towing limits and specific plate / insurance / even driver lic requirements the caps are starting to crack down all over on the little guys now . also in the 12k range you would be much better off with a gooseneck trailer / hitch . spread the load out better and haul a lot nicer for you . no massive end of the frame tongue pressure killing the ride .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
![]() Join Date: May 2015
Re: class 5 hitch
/\/\...what he said...I pull 9k loads with my 1ton....couldn't imagine 12k on the bumper...dot would have a field day with that
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 11-30-2018 at 12:18 PM. |
Re: class 5 hitch
thanks,
| Bookmarks |
