Drive Line Placement
So I asked and got some answers on another thread on here, but I thought I was hijacking too much, so better start my own thread.
So when I mounted my engine, I'm pretty sure I screwed up. At that time, I had my 4x4 S10 rear-end. Since, I've switched to an 8.8 Explorer rear, with coil-overs. I initially thought in this picture that the stock S10 driveline was in at an angle: Off of the passenger's side at the front, angling back and meeting the center of the vehicle at the transmission tail shaft. Thus, I mounted my LS that way. I now realize this is not the case, and I may have driveline vibration. But, with the 8.8 Output shaft 2" toward the passenger's side, should the engine be mounted the same?...2 inches toward the passenger's side? I likely need to straighten everything out. Which will include cutting and rewelding motor mounts, and probably modifying trans-crossmember. Or, do you think a few degrees of angle in the engine won't be a big deal? |
| Bookmarks |
