11-20-2003, 02:59 PM | #1 |
Aproximate weight of a 68 short bed, fleetside?
I have done a lot of searching, and havn't had much luck.
I have a 68 c/10 shortbed fleetside that i am restoring, Does anyone know what one of these trucks weight with a small block and a turbo 400? thanks |
11-20-2003, 08:41 PM | #2 |
Formerly yellow72custom
The weight on these trucks tends to vary quite a bit. GM said the curb weight on my LWB was 3800....but the scale i took it to put it at 3980 lbs. I would guestimate your SWB to be in the 3800 lb area, possibly less
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
11-20-2003, 11:46 PM | #3 |
My truck used to weight 3700 before I installed my LS1. That was with roll pans and an auto trans. My LS1 is 200 lbs lighter so it should weigh in a 3500 now.
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
11-22-2003, 12:48 AM | #4 |
thanks guys, gave me exactly what i was looking for
11-22-2003, 10:54 PM | #5 |
its all about the +6 inches
Some are a little heavier than others..my 69 GMC (1/2 ton short/fleet) tips the scales at almost 4000 pounds. No clue why...but it does.
11-22-2003, 11:06 PM | #6 |
that heavy chrome front grill steel is heavier than aluminum
it could be a lot of things. if you have different engine parts on, different wheels, bigger tires, spare tires. tool boxes lots of things. air conditiniong. just different things could play
70 longbed 496/th400/Ford 9" |
11-22-2003, 11:55 PM | #7 |
Thing is, I have headers, alluminum intake, no smog crap, no A/C (never did) alluminum rims no tool box, minimal junk in the cab (25 pounds at best...)
Nothing explains why this thing is such a tank ass. |
11-23-2003, 12:05 AM | #8 |
The stock manual trans weighs a ton. So does the stock xmember that held it in place. Bumpers are heavy too.
