Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
An insect nearly burned down my 67 stepside.
Boy I bet I get a lot of views with this one.
I've had my share of problems with the engine in this truck. It started with when I bought it and discovered it had flat lobes on the camshaft. I got a completely rebuilt engine along with the truck, so I simply installed it in place of the bad cam engine. Here's why the engine flat lobed the cam. At least I think so. Notice the oil pump pickup screen is missing. It was laying in the oil pan when I took it off. So I decide to just install the rebuilt engine and start fresh. Get it all in and add water to the radiator. It keeps going down every day for a few days, no leaks on the floor so I check the oil, aw shucks ( epithets deleted). Water in the oil and up on the lifters when I primed the oil pump. It turns out that the block is cracked in the intake valley and it was small enough that I didn't notice it when I installed the lifters and the intake. After due consideration, I decided to boil out the flat lobe engine and use it. It only had 5,000 miles on it and no wear on the bores and the heads were in great shape. Both these engines had been bored to .030 over so I swapped all the new stuff from the cracked block engine over to the flat lobe engine while taking all the necessary measuring precautions. Fast forward to engine install and new cam wear in for 20 minutes. I'd preset the distributor, all the valve tappets, and the timing so it was ready to go. I decided to start the engine from the engine bay instead of in the cab, so I could monitor everything. I also jacked up the rear end so she couldn't take off on me in case the tranny linkage was adjusted wrong. So here we go, it rolls over about twice and fires right up, speeds up to the required 2 grand, and sounds strong, pumping 75 psi oil pressure running as smooth as silk, with that nice rumbling sound that only the dual Flowmasters can make. So I'm patting myself on the back and about to feel great and I notice the water temp gauge is climbing fast. About this same time I noticed that there was some hot red fluid boiling up out of the transmission dip stick all over the place. It made a huge mess so I let it cool down and decided that the 16 inch electric fan wasn't cutting it. I pulled that thing off and replaced it with the original shroud, and a seven blade fan off the original engine. I wanted to be sure it would cool properly. Now after draining and replacing the burnt trans fluid ( yeah it got that hot) I was ready for round two. Now here's where it gets real interesting. I top off the radiator, no leak downs this time, checked all the fluids after the fresh oil change, and hit the remote starter button. She fires right up and sounds great, temperature comes up to 180 and levels off and holds at 175 to 180, so far so good. So I figure the overheating engine caused the trans fluid to get too hot and up it comes. WRONG! I notice a leak under the oil pan and a small drip of oil on the floor so I investigate and the pan gasket was leaking. All the time my temperature gauge is reading 175 to 180. Got that fixed or so I thought. So I shut it down again to replace the gasket and all off a sudden here comes the trans oil up out of the dipstick again. EXCEPT THAT this time it got on the hot exhaust pipe and HOLY HELL there are flames coming up in my engine compartment. PANIC! PANIC! PANIC! Luckily I had the fire extinguisher handy and was able to put out the flames quickly. I singed the spark plug wires otherwise no real damage except to my underwear. Now i'm really puzzled. What had caused the transmission fluid to boil over if it wasn't the engine overheating? I'm really thinking hard on this one and decided, if it wasn't the engine overheating then it must be the oil cooler lines plugged, or the transmission pump wasn't working. Then it hit me. While I was cleaning the fuel tank and re-installing the lines, I pressure checked the system for flow, and the tank bowed when I hit it with a low pressure charge. I knew the tank was not plugged so it must be a line. I was right, one of the line sections that had hung on the wall was plugged. It was brand new so how could that be? Are you getting it yet. That's right, when I checked the line and ran a small rod through it, a bunch of dirt came out and the line cleared. AHA! it was a dirt dobber (mud wasp) that had gotten into that 3/8ths line and plugged it up. Could it be that the transmission cooler line had suffered the same fate. I yanked them off and sure enough the output line from the transmission was plugged about three inches in. The end result was that the transmission oil was just circulating in the trans and building up enough heat to cause it to boil over when I shut the engine down. If i'm really lucky, I didn't burn up the clutches in the trans. So that my friends is how an insect almost burned down my truck. What A loss that would have been.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: An insect nearly burned down my 67 stepside.
I guess I'm one of the first of many to read this. Quite a story, that's for sure! Thanks for sharing with us. Stupid bugs, they can annoy us in so many ways -- but I've never heard anything like that before. Glad you figured it out & hope there was no other serious damage done. Wow.
laying low
![]() Join Date: Mar 2001
Oh yeah. Trans fluid on the exhaust is bad. Worse if you are under the vehicle when it decides to puke it up. You dodged a bullet V.
I reluctantly broke in my new engine with the truck inside my shop, raining. I was by myself and had a fire extinguisher handy. On jack stands too. I ran short of hose clamps so I just stuck a short piece of new heater hose with a bolt inside it onto the intake nipple and went on about running it in. As the temp began to come up so did the cooling system pressure when BAM! That short piece of hose shot all the way across the shop followed by a long stream of hot water too! ![]()
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
The Older Generation
Sounds to me like if you didn't have bad luck you wouldn't have any luck at all..... ![]() LockDoc
#5 | |
Msgt USAF Ret
#6 | |
Wow! Things are looking up that's for sure.... ![]() LockDoc
![]() Join Date: Dec 2013
"Notice the oil pump pickup screen is missing. It was laying in the oil pan when I took it off."
I've never been happy about tack welding a pick up tube to the pump on a fresh engine but that's the way it's been forever . My small block was a fresh rebuild when I bought it and to be on the safe side I opened it up and replaced the pump with a Melling and new pick up tube . I looked around and found this pick up tube retainer and used it instead of tacking and it went on great and I'm a lot happier now , ![]() Mud bugs can ruin your day .Nothing runs like a Deere ,Check out Beet juice to fill the rear tires for traction and ballast ,Home depot sells tractor weights and foam filling the front tires will add traction and ballast also increases stability ,
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 12-01-2018 at 01:16 AM. |
Old member
Vett!
Dang man glad it didn't burn the truck up man! Glad your Ok to. I have had my share of bugs also on the ramp truck. I haven't been stung by a bee in a long time until this summer. They like making nests under the ramp bed. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Nov 2012
Wow, that is quite a story! Glad you figured that out! I feel your pain with those mud dauber wasps though. Since my 67 GMC sat unused for 10 years, some of those accursed insects built a vast megaopolis of a city all throughout it. Every time I use the crawler under it I find yet another nest that I somehow previously missed. I will bet that I have removed at least 70 - 100 mud dauber nests so far.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
#10 | |
![]() Join Date: Oct 2009
I also have a severe dirt dobber problem here!
They also stop up the trans vents. It won't blow out with air! You have to run a wire in the lines to clear them.Then air. I stuff rags in the end of air filter housings for the same reason. I need a good way to get rid of them if anyone knows of one! Mike. ![]() |
Bugs suck.
#13 |
Ah yes, Murphy's Law!
#14 |
I was thinking it was a joke by from the title.
I'm glad you caught it in time. Besides the truck that looks like your house in the picture it could have been a 2 for. Now you have a very good strange but true story and the rest of us will now double check out lines. |
#15 | |
![]() Join Date: Apr 2016
#16 |
I totally missed the subj because I got distracted by the guard dog and the tractor... Mud daubers are horrible around here. My 76 got infested and I had to go to Mop 4 with a pith helmet, face net, garden hose, and kill spray to get rid of em. I think the neighbors though I had lost my marbles. They had made homes in every stake pocket and, unfortunately, all the way down my carb throat into the intake. It was maddening... Was taking things apart and the fricking things kept flying out. Finally eradicated though...
#17 |
I can attest to the quality of Deere products from the past. My 1999 4100 still performs perfectly.
71 C-20 07 Magnum RT AWD |
#18 |
![]() Join Date: Jul 2015
Wow! Glad to hear problem things were keep to a minimum! And First off your OK. Little things cause big problems I learn from the folks here. Recently I thought my engine was flat lobbed. Found out later after some speaking with a tech that Accel distributor coils have an extremely tight tolerance, like 500 ohms!
Talk about mother nature wrecking havoc! I would not have gotten to where I am at today without learning from you, Now the stars have lined up for you, thankfully! |
#19 | ||||
Msgt USAF Ret
Funny she thinks she is Cujo, her name is MIdget but she thinks she's a giant. I plan to use it a lot and next to my truck it is my favorite toy.This is now my favorite color. Quote:
And thanks to all my good friends here, may you all have a MERRY CHRISTMAS and happy New Year.
#20 |
You call that a hard luck story? That's nothing. I drove my hotrod S10 with a 383 down to my cousin's about a 1/4 mile from my house and the oil pressure dropped to zero as I was going up his driveway. He's an old time hotrodder so he says no problem lets rebuild it. Same problem as you had, pickup tube fell out.
Ok after a couple months and about 3 grand the motor is ready. I decided not to put it back in my S10 but to put it in my C10. I also had dirt dobbers to clog every line hanging on the wall of cousin's shop. He knew he had a dirt dobber problem so we checked before installing lines. Now it's time to fire up motor and all is good. Motor runs strong and has good oil pressure pegs the gauge, that is until it gets hot then it has 0, zero, nada, no oil pressure. The big cam, big stall, motor didn't work for the C10 anyway so I just pulled it out and bought a GM L31-R crate motor. By then I'm back at my house with the new motor ready to install, just waiting for a day off work. That's when I get a call at work from a friend with a panicky voice saying someone just stole your motor. That's right someone(I know who) backed up to my shop pulled the doors off with their truck and stole my new motor. Homeowners Ins. said not to worry you are covered. Yes you are covered just some more paperwork and we will send you a check. Three weeks latter I get a call, " Sorry you are not covered after all" bye thank you. I am happy to say though today I have motor #3 a GM crate L31-R in my truck running great and the thieves are in jail(but getting out soon). I sold the S10 and 383 for pennies on the dollar and had to buy two crate engines to get one in my truck but I never gave up. |
#21 |
Great story. You wouldn't believe some of the insects, rodents, tools, mud and other debris I have pulled out of some of the antique farm tractors restored over the past 30 years.
Good rule of thumb - if it is a new or original oil line, fuel line, water hose etc it should be blown through with compressed air before going into anything. No problem with the mud dobbers here in Arizona..... but when I lived in Oklahoma and started the tractor in the shed after a winter's hibernation, boy were they there and pissed off. nest of 'em in the tractor. Musta got stung 5 or 6 times before running out of the shed. |
#22 | |
Dirt dobbers don't sting.Or yours' have some kind of weapon that ours don't have. ![]() Mike. ![]() |
#23 |
Sounds like something that would happen to me. Oh, the (long) story I could tell about what it took to get the old GTO back together and running.
Glad you slayed the beast and hopefully no permanent damage was done to the transmission.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
#24 | |
One thing I AM sure of - they were pissed off. |
#25 |
Msgt USAF Ret
Yeah I worried about that too. If it's bad I will probably get my 700r4 rebuilt or buy a newer one. Mine is an 84 but it was beefed up. I went to the turbo 350 because the front pump seal was leaking on the 700r4 and the PO had had it replaced twice and it still leaked. I had a shop replace the seal and bushing and flush the converter for $100, and when I picked it up they told me it wasn't going to last long because the clutches were bad, and the converter bearing was worn. After they took my $100 of course.
