Roadtrip!
![]() Join Date: Feb 2003
Auto tilt column.
I believe this is motor home or maybe a van. Feels tight with tight shifter. wiring has been patched at some point. Wheel is not included but will be sold separately. $185 plus shipping. Shipping should be $30-$50 depending on location.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
![]() Join Date: Jul 2016
Re: Auto tilt column.
Is the shifter pin hole still tight? Easiest way to verify is remove shifter then install pin. Should not be able to push in by hand. Lower part of hole should fit pin closely
Roadtrip!
Yep, the shifter pin hole is tight yet.
![]() Join Date: Mar 2000
That one is motor home. I've pulled a dozen of them. Van has the longer shaft and the shift arm is the same configuration as stock truck arm.
Saskatoon, Saskatchewan Canada |
I will take the column, let me know the shipping cost, I should have your paypal...its been a while though so please send again.
#6 | |
Roadtrip!
Eric
Please send me the size and weight maybe i can ship it cheaper. Can you take the short intermediate shaft off the end, size makes a big difference. I could use the coupler bolt if you can include it. I need your full name and address for the call tag.
Roadtrip!
Randy, PM sent.
