Dash Color
Cleaning up Zane's 71, notice the dash from the dash pad to the windshield is painted brown. Originally, thought it was dirt. The interior is saddle. Is this normal for the space to be brown or interior color?
Zane's 71 Build |
![]() Join Date: Aug 2018
Re: Dash Color
Good question.. I think the previous owner of my truck painted that space black, I thought it should be the color of the vehicle but when i had the defrost vents out they were saddle on the underneath side. Curious to find out the answer.
Doug ![]() 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US Last edited by DA71Grande; 12-02-2018 at 09:50 PM. |
Re: Dash Color
Mine is saddle, and it looked like dirt. Far as I can tell its original and should be that way. I dont think I'm wrong but I could be mistaken.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
![]() Join Date: Feb 2011
Re: Dash Color
FWIW....my '72 is sprayed body color behind the dash and up to the firewall. It's just not a solid coat because of the area and not needing as good a finish as something easily seen.
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
Re: Dash Color
My 72 is body color .
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Dash Color
My '72 K20 is body color. Its interior is all original paint.
Re: Dash Color
My 72 is black all the way through from dashpad to windshield!! Sorry not sure how to rotate the picture
Re: Dash Color
I didn't know some came with body color in that area. I'm used to seeing a matte version of the vinyl color painted there. I changed my '72 GMC from blue interior to saddle and that area is still dark blue.
![]() Join Date: Feb 2002
Re: Dash Color
I spray painted the dash under the windshield with flat black for anti-glare. Touch it up occasionally. The summer sun is harsh here.
My original dash pad was a dark silver gray, and the area in front was sort of charcoal, so I'm not far off with the black.
Re: Dash Color
Took a pic of the dash with the pad off. Dirty, but looks original. Feels like a flat finish. Not sure if that is sun fade or painted that way originally.
Zane's 71 Build Last edited by rcazwillis; 12-03-2018 at 10:13 PM. Reason: responded to wrong thread. |
Re: Dash Color
They used flat paint so the sun doesn't reflect off it. It's right.
Do it, Do it right, Do it right the first time |
Re: Dash Color
My 72 Blazer is ochre. The dash pad is sandalwood vinyl and the dash is painted flat sandalwood. The steering column is painted gloss sandalwood and the steering wheel is sandalwood plastic.
#13 |
Re: Dash Color
x2
72 C10 lwb fleetside -stock 350/350 combo |
#14 |
![]() Join Date: Jul 2016
Re: Dash Color
That area is always painted the color of the dash pad in a flat sheen. Never body color.
#15 |
Re: Dash Color
There is a also a rule on dash pad color...matches interior color except if tilt column then black dash pad, unless Cheyenne super, then some or maybe all get dash pad color that matches the interior color....someone can probably clarify this rule....
#16 | |
20' Daredevil (Ret)
![]() Quote:
I've said before, if you don't learn something every day, you're not paying attention! Thanks for contributing to this old man's continuing education.
#17 |
Re: Dash Color
My interior is tan, and it was black from the factory. This is a picture I found showing it prepped for paint (I had my interior painted century gold):
1970 C10 250 3-speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=650480 |
#18 |
Re: Dash Color
Also, if you have a blue truck, for example, the flat blue they use on the dash isn't a great match. They used the same flat blue in 69-70 for pretty much every shade of exterior blue regardless, I think.
#19 |
Re: Dash Color
Mine was a darker flat blue but not after I painted it the factory outer blue.
#20 |
![]() Join Date: Apr 2013
Re: Dash Color
Is there a paint reference for this? I need new defroster registers and would like to paint them to match.
72 Cheyenne Super C10 SWB 2001 Silverado 1500HD Crew 2011 Silverado 2500HD Crew Duramax (Hers) |
#21 |
Re: Dash Color
I'm not sure if this helps. I think the dash vents are color coded to match when you buy them.
#22 |
Re: Dash Color
Mine was vinyl when I bought mine, had 4x6 speaker holes. I had to cover them again with flashing and painted it satin black.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
