Best fan temps
I am running a 2001 5.3 4L60E. 2 electric fans.
Factory settings are fan 1 on at 219 F off at 212 F. Fan 2 on at 226 F off 219 F. Thinking about changing to Fan 1 on at 200 F off at 196 F. Fan 2 on at 206 F off at 202 F. I live in the mid west summer temps can run in the 100 F to 0 F in winter. Any body got any input on what is the best temps to set Fans at.
67 c20 68 c10 72 c10 69 GMC 72 short step |
Post Whore
![]() ![]() Join Date: May 2015
Re: Best fan temps
What's your engine operating temp?....they set my fans on at 175 and 180....my 6.0 never gets over 185 in summer even pulling 9500lb loaded trailer...I've been criticized for them being low on a LS engine but I've seen no issues arise from from it...that's just the way my dyno man set it up...
Re: Best fan temps
Thanks Greg
My 5.3 at idle gets to 220 F. I am still working on Bed & minor cab damage so I have not ran it down the road. Gm set the temps. at 220 F for more efficiency fuel economy. I hoping by lowering temps. I can squeeze another 200,000 out of this 5.3. I have 1 pcm set at factory temp. settings and 1 pcm set at lower temps. Here in a few months (when project hits the road) I can do some test runs see if temps. makes any difference.
![]() Join Date: Dec 2012
Re: Best fan temps
Not sure what right and wrong are.
I have a 180 stat. I have 2 fans and set low speed at 190 and hi speed at 200
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
Re: Best fan temps
from my understanding this "newer" gen 3 stuff runs hotter from the factory than what we normally like to see. They have a higher thermostat so those fan temps are probably right based on that. I think in part I understood it was for emisions but I am not sure on that.
I installed a 180 thermostat in mine and in turn lowered the temp settings for my fans to match that. It wont hurt to run hotter like yours are set I just didn't and don't like seeing my temperature that high. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Post Whore
Re: Best fan temps
My LQ9 came with a 160deg thermostat...I assume from the factory...
Re: Best fan temps
My '84 with a LQ4 has a factory 195* thermostat. It runs at about 197* all day long. Factory dual fan setup only comes on when sitting in traffic in the summer. Brings it right back to 195* in about a minute. No A/C so I don't think my fans have ever been on high. I am running a gigantic Cadillac Escalade radiator and factory relays fan set up.
My crasher LQ4 in my 86 has a clutch fan and 195* thermostat with no upper shroud and also runs at 197* all day long. 1986 style radiator. |
meowMEOWmeowMEOW
Re: Best fan temps
a 160? AFAIK that didn't come out of the factory that way. 160 is a pretty cold stat, especially if your in an area that gets all 4 seasons.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Post Whore
Re: Best fan temps
I was surprised when I changed the water pump and found that...it was low mileage and didn't look like it had ever been apart...came from a escalade....
#10 | |
Re: Best fan temps
