Old 12-04-2018, 05:31 PM   #1
ratman90
AC/Heater housing sticky stuff
Working on a previous truck, it had this gritty rubbery stuff insulating the housing where the two came together. I removed it while working on it and then misplaced it.
Any ideas what this stuff is so I can get some more?
1972 C10 LWB 2WD
307 4 speed
Rescued from Field July 2017
ratman90 is offline   Reply With Quote
Old 12-04-2018, 05:34 PM   #2
68Gold/white
Re: AC/Heater housing sticky stuff
Parts stores sell it. Getting the sales person to look for it in a book may be a challenge, depending on where you buy parts.....
68Gold/white is offline   Reply With Quote
Old 12-04-2018, 05:52 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
O'Reilly sells it in a 30' roll. Murray #59010 - I used it on my '65 Bel Air this summer when I rebuilt the a/c system. If you go in there and ask anyone born after 1980 about it, they probably won't know what you're talking about!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-04-2018, 06:23 PM   #4
notsolo
notsolo's Avatar
Butyl tape, is what it's called, comes in flat 3" wide 1/4" thick, all the way down to rope strips, 1/8" around... stretches, squishes flat to seal when clamped between 2 surfaces... gummy all the way thru..Most of the time its gray, but can be found in black.
notsolo is offline   Reply With Quote
Old 12-04-2018, 06:26 PM   #5
projectking
projectking's Avatar
Strip caulk from 3m
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 12-04-2018, 07:26 PM   #6
ratman90
I think Boss Hogg has it up on top.
Looking online with the words insulation tape
I found a couple of websites of 72 Gran Torino Sport 17 year Barn nap find and a hot rod installing old Air Products hurricane heat and AC hot rod Network. Had pictures of it.
So it's looking like that's what I need. I really do appreciate it guys!
1972 C10 LWB 2WD
307 4 speed
Old 12-04-2018, 07:39 PM   #7
Jrainman
Jrainman's Avatar
Yes its called Butyl tape it comes in a varity of forms,but the tape type is what you want , if you have a hard time finding it you can always find it at your local HVAC supply house or roofing supply that carries flashing and or metal roofing.
Jrainman is offline   Reply With Quote
Old 12-04-2018, 08:08 PM   #8
projectking
I was born in ‘81....
3M 08578 Black 1' Strip Calk https://www.amazon.com/dp/B000PEZ1L4..._CAXbCbT8GHWNF
67 Chevy C10 LWB
90 Mustang Gt
Old 12-04-2018, 08:26 PM   #9
ratman90
Attached is what this stuff looks like. It's certainly not grey butyl to hold in an RV window that's for sure. Is the grittiness that's in it from Cork?
1972 C10 LWB 2WD
307 4 speed
Old 12-05-2018, 04:58 PM   #10
notsolo
notsolo's Avatar
...on Ebay.... $8.99...Camaro air conditioning insulation wrap, evaporator core upper tube.
Old 12-05-2018, 08:40 PM   #11
JerryIndy2112
JerryIndy2112's Avatar
I work in HVAC. We use same stuff. It is also called cork tape. What I use comes on a roll about 2" wide. It is just a sealer that does not come loose if it gets wet.
JerryIndy2112 is offline   Reply With Quote
Old 12-05-2018, 10:39 PM   #12
ratman90
Awesome thank you guys I was wondering if it was that cork stuff?
1972 C10 LWB 2WD
307 4 speed
Old 12-05-2018, 10:58 PM   #13
tdangle
tdangle's Avatar
You can get it from NAPA
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
