Old 12-05-2018, 09:06 PM   #1
pwdcougar
pwdcougar's Avatar
Suburban rotisserie question
I have the rough body work done on my body shell and the next step is to put it on the rotisserie. I’ve saved three or four pictures of suburbans on a rotisserie and I don’t see much in the way of the cross bracing within the shell. Does anyone have recommendations on welding in cross pieces? I was thinking about putting an X right in the middle of the body.
Any help here would be greatly appreciated!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 12-10-2018, 01:28 PM   #2
Burb
Coordinator of Synchronicity
Burb's Avatar
Re: Suburban rotisserie question
... all my Xs in Texas ..... Helpful?
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 12-10-2018, 06:51 PM   #3
pwdcougar
pwdcougar's Avatar
Yes! Thanks Rick
Paul
Old 12-14-2018, 04:02 PM   #4
Burb
Burb's Avatar
found this too ... the rear hook up on the rotisserie
Rick
Old 12-14-2018, 10:43 PM   #5
pwdcougar
pwdcougar's Avatar
Thanks again Rick. Your rear hook up was done from the bottom of the body. Is there a reason you did it that way? I've seen a few where they went to the top of the floor. Mine would only hook up that way because of the rear door sill. If I get longer bolts I can add another piece of 2" tube and mount it underneath.
Paul
