Old 12-07-2018, 11:40 AM   #1
botoepfer
Active Member
botoepfer's Avatar
Power steering brackets needed
Hi I am planning to install PS on my 63 with a 230 in line 6,, any help
botoepfer is offline   Reply With Quote
Old 12-07-2018, 12:06 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Power steering brackets needed
PS Bracket:
https://www.ebay.com/itm/10003-292-C...wAAOxyyghQ65Uy
Or if you want Alt, PS and AC brackets:
https://www.ebay.com/itm/10037-194-2...oAAOSw1vlUxumV
Old 12-08-2018, 12:02 AM   #3
andyh1956
The text in the ebay add says this #10003 is for a 292 only, the smaller displacement engines use #10002.
I removed ps from an integral head 250 to use on my early 250 & noted a different water pump. The flange was in a different location. Not sure if they all that way.
andyh1956 is offline   Reply With Quote
Old 12-08-2018, 08:03 AM   #4
1966c10shrtbd
1966c10shrtbd's Avatar
http://www.alangrovecomponents.com/C...x_Cylinder.htm
1966c10shrtbd is offline   Reply With Quote
Old 12-09-2018, 11:20 AM   #5
The Rocknrod
Moderator
I found a web site also: https://davisspeedequipment.com/
Old 12-13-2018, 12:08 PM   #6
botoepfer
Active Member
botoepfer's Avatar
ROcknrod The Davis Site has some great stuff,, Thanks
