Old 12-08-2018, 07:58 AM   #1
bigmoe
bigmoe's Avatar
79 rear end into 65?
So I've got a line on a 79 1/2 ton that I plan to scavenge the front suspension, etc., from but I'm tossing around the idea of using the rear end, especially if it has a better ratio. I understand it will be 3/4" wider on each side. I can manage to mount the pads for the trailing arms and maintain the proper pinion angle but what do I do to mount a panhard rod?
bigmoe is offline   Reply With Quote
Old 12-08-2018, 09:35 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 79 rear end into 65?
Are you planning on dropping it? and how much?
You can go aftermarket like POL - https://www.performanceonline.com/60...pension-parts/
A 65/66 will have a better frame mount for the panhard bar IMO for clearance if your dropping it along with the POL bar.
There is one other company I used previously, they make a great product but it hits the frame on the P-side when dropped: http://67-72chevytrucks.com/vboard/s...1&postcount=31
Old 12-08-2018, 11:35 AM   #3
AcampoDave
AcampoDave's Avatar
And if you dont plan on slamming it, you just cut the old mount off the original and weld it on to the replacement.
AcampoDave is offline   Reply With Quote
Old 12-08-2018, 11:53 AM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
https://search.yahoo.com/search?p=+3...p=mss&ei=UTF-8 You could try one of these. I'm not saying these will work but you could call and ask. Seems like an easy alternative. https://www.superchargedmotorsports....1ebc1a044d5ad8
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-08-2018, 03:38 PM   #5
bigmoe
bigmoe's Avatar
Only a 3 to 4” drop with Jeep coils.
Old 12-08-2018, 03:39 PM   #6
bigmoe
bigmoe's Avatar
The original mount is part of the original centre sections casting.
Old 12-08-2018, 08:43 PM   #7
AcampoDave
AcampoDave's Avatar
Right, i thought that started in '66. Perhaps you can salvage one from somewhere. I have managed to do that before once or twice. Anybody who is switching to something more "high tech" would have no use for the pre '65 tube mount panhard mount tower.
