12-10-2018, 11:03 AM | #1 |
old leaf springs
Hello
I have a pair of rear leaf springs that I bought 25 years ago. They have been sitting since then in my shed. I want to lower my blazer and remove the lift. any reason not to use them. can springs go bad just by sitting Thanks |
12-10-2018, 04:12 PM | #2 |
Re: old leaf springs
If the spring eye bushings look OK, I'd go ahead and use them. The only things that could damage a set of springs would be exposure to extreme heat like a fire, or expose to salt water like being submerged in the ocean for a long time. Heat from a fire will remove the temper from the steel and render them useless. Deep corrosion pitting will also weaken the springs. You are probably good to go.
12-10-2018, 04:52 PM | #3 |
Thanks for the reply. They have new eye bushings So i will go ahead and use them
