Old 11-21-2003, 12:25 AM   #1
Injected68LS1
Injected68LS1's Avatar
Do Disc Conversions Change Wheel Offset?
So here is what I am trying to figure out.
I'm converting to a 5 lug disc brake setup from a 6 lug drum brake setup. To use the brakes, I need to have my new 5 lug wheels. So I don't want to order expensive wheels and find that the disc spindle has a changed offset. Any insight?
Thanks in advance.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 11-21-2003, 12:48 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Drop spindles widen the track by about a 1/2 inch PER SIDE.
If you run drop spindles and exact same size tires front and rear, it will be plainly obvious.
Non-drop spindles, I do not know.
Old 11-21-2003, 03:45 AM   #3
Injected68LS1
Well, the new brakes will be on drop spindles.
So it should be safe to assume that I need to order wheels with 1/2 more backspacing than my current wheels?
Old 11-21-2003, 03:47 AM   #4
Injected68LS1
But what about the difference from drum brake to disc brake????
Old 11-21-2003, 07:10 AM   #5
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
I,m trying to find out also, I swapped to dics from an 85 and bought 6 lug rotors. I have a set of 16x8 with 5'' offset and need to know if it will work.
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 11-21-2003, 08:41 AM   #6
SCOTI
SCOTI's Avatar
I looked this up years ago when I did my 67 (back around 1988/89) & the difference in track width was like 1" (1/2" per side) when swapping from drums to disc. This difference was related to the disc brake spindle & hub, so I found drop spindles don't widen the track width any more than stock disc spindles.
16x8 w/5" offset would work fine. I've used my 18x8 w/5.25" offset on my 68 & 74 trucks w/o issue. You will need to trim the lip of the lower control arm slightly for lock-to-lock steering clearance.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-22-2003, 04:28 AM   #7
Injected68LS1
Called ECE today. They said that the drop spindles and disc brakes move the track out 1-3/8" PER side. I never thought it would be that much. Hopefully that will hold true when I get everything assembled.
