12-12-2018, 08:38 PM | #1 |
3 Speed Transmission
Guys I need some help! My trans blew apart and I found another one local. The guy is saying it is out of an Impala; are they the same as our trucks?
1965 327sbc 3 on the tree swb truck, trans is a 3 speed with a 4 bolt side cover. The one from the impala is identical from the pictures. Thanks so much |
12-13-2018, 12:10 AM | #2 |
Re: 3 Speed Transmission
The case will bolt to the bell housing just fine, but make sure your tail shaft is the same length. Some 4 bolts have a long tail shaft, others have a shorter tail shaft. Since they are both 4 bolt covers, you can swap side covers to retain the truck shift forks
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
12-13-2018, 04:50 AM | #3 |
Perfect, thank you very much
12-13-2018, 10:52 AM | #4 |
The diameter of the front bearing retainer may be smaller, in which case it will bolt to your bellhousing, but won't be indexed properly. You might want to check that - bearing retainer outside diameter should match the inside diameter of the round hole at rear of your bellhousing. You can probably swap over the bearing retainer from your truck transmission if they don't match.
12-13-2018, 11:22 AM | #5 | |
12-13-2018, 02:13 PM | #6 |
Be sure to ask the seller of the Impala trans if it has EVER jumped third gear.
At least you'll be able to Hear him say it even if it does... |
12-16-2018, 06:46 PM | #7 |
Great time to upgrade to a full synchro 3 speed.
12-17-2018, 12:04 PM | #8 |
