I am looking at getting a new steering column for my 1971 GMC long bed and I am having a hard time figuring out what I need. I have been looking at eBay and for $244 I can get one which sounds like a great deal but I am not sure if it’s to good to be true. I am also not sure if it needs to be 32in 31 or 30. I would love more room since I am 6’3 but just not sure. I have been reading on here but the more I read the worse it gets.
Thanks PS my truck is no 50k show truck its a daily driver. |
Re: steering column for my 1971
I can't help you with a source for purchasing a new/refurb column, but you should look into rebuilding yours. Some of the parts are difficult to find and/or a bit expensive, but you may not need those items. I just restored my tilt column with some reading here and on the net AND a fair amout of patience I accomplished very good results. I did not have to source the hard to find bits becuase mine were still in good working order. Just needed some cleaning and greasing and paint.
I think there is someone here that rebuild them and has a good reputation, but I can not recall is name at the moment.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
The board member in the link rebuilds tilt steering columns and has sold lots to board members and 0 complaints. I'm sure he could fix you up with a non-tilt column if that is what you want and you won't have to worry about quality.
http://67-72chevytrucks.com/vboard/s...d.php?t=758922
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
I bought a rebuilt tilt column from 70shortfleet for my 70 and couldn't be happier. Be careful about buying one of those cheap China made columns.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
I also got mine from 70shortfleet and it is extremely nice. Hell, even the shipping crate was a work of art!
Thanks for the info but mine is not a tilt and has had a ruff life. I am looking to get a tilt column hopping it will give me some more room. So what length of shaft did you buy?
![]() Join Date: Apr 2010
If you need more room, I do a custom tilt that is 2'' shorter than the stock factory tilt and it will give you the extra room you are needing. Just did 2 of those this week. They run $650 plus shipping, thanks, Les
@ MHeffeGMC71 - there you go, straight from the horses mouth! Again, Les does some fine work. You won't be disappointed.
#9 | |
Those columns are often "generic", not exactly sized for good fit, requiring you to buy additional parts to mate with your steering box, shifter, wheel, or wiring harness. There are some excellent members on this site that rebuild original columns, and excellent vendors here that can get you the best deal o a high-quality aftermarket column (I've used several IDIDIT columns and recommend them). I'd recommend you look into those. Everybody loves a deal, but like a lot of things in life, "you get what you pay for" as for size, depending on column shift or not, and the column you choose, you can adjust the column to get an inch or more of additional clearance, and also consider some steering wheel options to get additional room (trading off dish and diameter for a comfortable position) --Steve
Help! My project parts hauler became a project! |
In my opinion nothing works better on these old trucks than OEM parts whether NOS, refurbished properly or just plain used and detailed.
