Old 12-13-2018, 06:50 PM   #1
AZ 67 C10
AZ 67 C10's Avatar
67-70 center link
It appers I have a 71+ center link that I didn't realize when I tore my front suspension apart and replaced it all. I have 67-70 ball joints and spindles and am looking for a 67-70 center link, but it doesn't seem like hardly anyone makes them. Does anyone know where I can source one from?
AZ 67 C10 is offline   Reply With Quote
Old 12-13-2018, 08:06 PM   #2
michael bustamante
michael bustamante's Avatar
Re: 67-70 center link
those always get replaced when guys do the disc brake / power steering conversion. ( a must ) if you have been swapped to disc brakes and/or power steering you really should just get 71 inner and outer tie rods. or cpp sells the conversion rods.
if your manual steering and drums in the front just look for one on the for sale ads on here
1967custom
michael bustamante is offline   Reply With Quote
Old 12-13-2018, 09:15 PM   #3
AZ 67 C10
AZ 67 C10's Avatar
It has been converted to front discs and has power steering. I guess since I didn't do the conversion I never thought twice about it and ordered stuff for the year of the truck, lesson learned. I'll see what cpp has for conversion rods since I don't really want to replace what's already been replaced with 71+ stuff.
Old 12-17-2018, 11:30 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yeah, no one makes the center link because it is a non wear item. You will have to find a used one. I had to swap mine out because someone used it to pull the truck and put a curved bend into it. I found a guy parting out trucks on Craigslist and got one that way.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-17-2018, 11:22 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Swapping the centerlink is not a must do item.
Run some conversion tie rod sleeves with 67-70 outers.
Then you can use 71-72 tie rods to connect to your center link.
Here’s the catch:
67-70 outers are LH thread.
So you will need to use 71-72 outers (rh thread) in the inner location.
Keith
Convert to disc brakes.
Old 12-21-2018, 10:39 PM   #6
AZ 67 C10
AZ 67 C10's Avatar
Here’s the catch:
Before I read this I had already ordered 71-72 inners from Moog and the conversion sleeves from CPP. The 71-72 tie rod is 11/16 compared to the 5/8 67-70, but the ball joint is hardly bigger and fits sloppy in my center link, just less sloppy than the 67-70 ones. My idler and pitman arm fit correctly in the center link and just eyeballing it I can tell the size difference.
Is there a difference between 71-72 outers vs inners ball joint size? Or are 73+ tie rods different than 71-72? Looks like they have different part numbers on Moog's website.. Either way I need an outer to run in the inner location.
Old 12-22-2018, 02:36 AM   #7
lolife99
lolife99's Avatar
71-72 tie rods are the same, no matter inner or outer, just different thread direction.
Tie rods are:
63-70
71-72
73-87
Same as balljoints.
Keith
Old 01-02-2019, 12:31 AM   #8
AZ 67 C10
AZ 67 C10's Avatar
OK so i've tried 67-70, 71-72, and 73-87 tie rods and none of them work with the center link I have. The taper on all of them is too small for the center link so they fit sloppy. The taper on the center link is the same size for all 4 of the holes. The idler/pitman arm taper fits in every hole on the center link if that explains anything.. I'm open to any suggestions, at this point I have enough tie rods to build a front end twice over...
Old 01-05-2019, 08:12 AM   #9
Jrainman
Jrainman's Avatar
I would highly suggest you read Lolife99 information posted here in Suspention go to the thread/thread stater catorgory and click on Lolife99 DISC TO DRUM Conversion ,he gives you very detailed information on what you are trying to figure out . all your answers are there
Jrainman is offline   Reply With Quote
Old 01-05-2019, 12:38 PM   #10
AZ 67 C10
AZ 67 C10's Avatar
Thanks for the suggestion on the disc to drum thread its packed with info. After reading through it, i'm still unsure of what I have going on without knowing what the PO did. After trying 3 different tie rod configurations (67-70, 71-72, and 73-87) my conclusion is the centerlink is from an earlier model (60-66) or someone enlarged the taper in it. So my question is, did 60-62 or 62-66 trucks centerlink have a larger diameter taper than later years?
I know this shouldn't be this complicated but I appreciate the help. Lesson learned, don't toss your old parts until you verify the new parts are correct.
Old 01-08-2019, 11:26 AM   #11
chevy_mike
chevy_mike's Avatar
I think the taper increased in size as they got newer. GM kept beefing them up. I wonder if the center link is from a C20 or C30. They might have used bigger tie rod ends.
Old 01-08-2019, 07:46 PM   #12
77c10bowtie
77c10bowtie's Avatar
Turns out inner tierods from my 77 fit the taper on every hole of the centerlink he has. So he could use 75+ inner tierods and solve that issue but he still has the 67-70 spindles and they use a slightly smaller taper and smaller threaded end to go to the adjuster sleeve so either someone makes a tierod that has the larger threaded shank for the adjuster or we will have to drill the taper larger to use a 75+ outer tierod also
77c10bowtie is offline   Reply With Quote
