Old 12-13-2018, 07:00 PM   #1
weedoublewide
Intake headers LS 6.0 to sm 465 1970 gmc
Good evening everyone,
I've run into a clearance problem involving my exhaust headers with bolting an LS 6.0 to an SM 465 transmission. I was wondering if anyone has encountered this problem or knows of some block hugger type manifolds that they've used in the past on prior projects.
The Gen 1 exhaust manifolds, like the ones from the sbc 350, would be perfect as they're a tight fit to the block. I found a pair of Hedman 68520 but they protrude out 4.5 inches out past the frame.
I also tried a pair of Hedman 45660 headers but was informed after I tried installing them were for hydraulic clutches setups, not manual clutches.
Any and all advice is greatly appreciated,
Thank you and Merry Christmas,
double
weedoublewide is offline   Reply With Quote
Old 12-13-2018, 09:01 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Intake headers LS 6.0 to sm 465 1970 gmc
i used highly modified headers for a LS hummer...ls3 or tbss manifolds might work
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-14-2018, 06:40 PM   #3
weedoublewide
What transmission were you running with those headers?
Old 12-14-2018, 07:11 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I don’t have the manual but...I used Sanderson CSLS1 shortie headers. They work well
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-14-2018, 07:15 PM   #5
mongocanfly
Post Whore
nv4500
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-14-2018, 07:38 PM   #6
weedoublewide
Originally Posted by mongocanfly View Post
nv4500
If those would work I'd install them in a heart beat lol. Unfortunately my clutch fork and linkage is getting in the way of the collector =( but thank you for your help, I appreciate it.
Those look like the Hedman ones i tried. I wish they would've worked because they are a good quality header. Downfall is the clutch fork is getting in the way of the collector =(. I appreciate your help my man, thank you!
Old 12-14-2018, 10:51 PM   #7
mongocanfly
Post Whore
I also have a manual clutch...with linkage, clutch fork and all...
The hummer headers drop straight down at the back cylinder and the turn back...they'll clear all the linkage.....would I recommend you try em? Nope...had to do a good bit of modifying
The headman claim they'd fit fit but they wouldn't clear the linkage..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-16-2018, 04:48 PM   #8
weedoublewide
My apologizes my man.
So how much modifying did you have to do? I've never installed exhaust headers before so in my mind they're suppose to fit like a drop in; hassle free and all that stuff.
Yea I tried those hedman ones as well and scratched my head thinking I was going crazy because im pretty good at putting the square block in the square block and those headers WEREN'T fitting at all. That's when I got on the phone with someone and they said yeeha those are for manual transmissions with hydraulic clutches.
Old 12-16-2018, 08:24 PM   #9
Macdaddy1
Mine is on a 5.3 but i Used speed engineering ram horns which dropped straight down and missed all of the linkage.
Macdaddy1 is offline   Reply With Quote
Old 12-16-2018, 08:42 PM   #10
mongocanfly
Post Whore
No apologies needed.....had to cut the collectors off and turn them....had to notch frame...had to do some tweaking as well....I wouldn't recommend doing what I had to do...try the ls3 or tbss manis and see what you got...or go shorty headers....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-18-2018, 01:30 PM   #11
MalibuSSwagon
I used f-body manifolds on my C10, cleared the SM465 hydro linkage.
MalibuSSwagon is offline   Reply With Quote
Old 12-20-2018, 12:07 AM   #12
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Malibu-
Your manifolds look like this correct? Help me out with what you have for a linkage - hydraulic kit or the old GM Z-bar with a ball mounted on the LS?
Loren
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 12-20-2018, 09:59 AM   #13
MalibuSSwagon
Here's some pics of one. It might be what you need. My truck has the factory hydro setup being an 86. Occupies about the same space as the manual linkage.
https://www.ebay.com/itm/00-01-02-Ca...-/232250766098
Easy to find these used.
Old 12-21-2018, 06:23 PM   #14
crazy longhorn
Fabricate till you "puke"
I used Hooker street rod shorties on my swap, along with a set of stainless down tubes (Speed way motors, Summit,Jegs). All of the mechanical linkage will clear, but you need a bracket for the block pivot ball. My engine , is set 1 inch forward , from I-6 spot, & runs a 55-57 bell housing. On the headers, you will need aftermarket wires & sleeves. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-05-2019, 08:04 PM   #15
weedoublewide
Thank you, those speed engineering ones that drop down the middle worked PERFECTLY.
I didn't have to make any mods or fabs. Took me a beer to install, so I drank 5 more looking at all that hard work .
Now its time for in coils, intake manifold, the software so I can blow something up ^____^
Thankyou everyone for your info and experience on from all of your projects. I greatly appreciate it!
double
