Sway bar
My 68 C10 doesn't have a sway bar what are the benefits of adding one is it worth it
Re: Sway bar
Worth it all day long. Do it
Re: Sway bar
X10!
Best bang for the buck. Especially if you grab a used one. '73-'87 C series trucks are a direct bolt in and are plentiful in the bone yards.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
#4 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Sway bar
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
So,, what else you got???
![]() Join Date: May 2010
Re: Sway bar
I put one on the shop truck. It sure corners a lot better and is more fun to drive. Very good, inexpensive upgrade.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks.... Sorry, we CANNOT ship larger parts. Thanks.
Re: Sway bar
x2 on what Already Gone said. That is exactly what I did. However, any sway bar (new, used, OEM, aftermarket, size) will be a huge improvement.
![]() Join Date: Jan 2017
Re: Sway bar
Yes, nice upgrade. Only watch what you buy as far as aftermarket. My aftermarket did work but I had to modify it a little to keep from hitting a tie rod as I recall. I recall I had to leave a spacer out maybe. I think mine was from Brothers.
Re: Sway bar
If you're lowered. Add the lowered brackets for more road clearance. First pic is the stock bracket. Second is the lowered one.
Re: Sway bar
any retrofit for a rear sway bar? does the truck arm system even really need one?
70 Chevy C-10 short step 250/3 on the tree Owned: 71 longbed Cheyenne 70 swb |
Re: Sway bar
Yes, I used the CPP 7401, though there are others available. It's a 1-1/8" bar. Easy to install and keeps the truck super level.
72 C10 lwb fleetside -stock 350/350 combo |
Re: Sway bar
Yes the rear benefits as well. Have a look at the rear of most new trucks these days and you'll see sway bars.
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Re: Sway bar
i know ccp made one but is there a later model that will work for cheaper like the front
#13 |
Re: Sway bar
Yes, there are. Use the search; I've seen older threads on it. I think a Camaro bar was one of the ones I had seen a thread on.
#14 |
Old member
Yes I had the camaro bar on my 71 before I did the No limit shock relocator and took it off. Didn't need any longer and it was in the way of the install.
Here is the link of my install. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=304267
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#15 | |
Re: Sway bar
https://www.hellwigproducts.com/prod...artnumber=7401 https://www.summitracing.com/int/parts/hel-7401
#16 |
Re: Sway bar
Got one off a late 80's Suburban in a local boneyard...best $40 improvement...came with brackets & fit my 72 C-10 perfect.
#17 |
Re: Sway bar
Getting a used sway bar from the 73–87, do you have any problems with the lowered trucks, the sway bar is bottoming out
#18 |
Re: Sway bar
You can use the shorter brackets on the frame as pictured previously or I think (needs confirming) you can use the stock brackets and instead of the bushing pointing down point it up instead inside the bracket.
#19 |
Re: Sway bar
You can forego the standard or lowered brackets and bolt the bushings directly to the frame instead.
#20 |
Re: Sway bar
I don't know, but looking at the price difference between the too, maybe not. The Hellwig piece is way more expensive.
#21 |
Re: Sway bar
Wow, it is a lot cheaper at CPP.. That makes me wonder about the quality of the CPP sway bar.
#22 |
Re: Sway bar
I hope the CPP front sway bar is a good one. I have one on the way as we speak.
#23 |
![]() Join Date: Sep 2014
Re: Sway bar
Why do some caution against a rear sway bar? I don't remember where I read that so I may be wrong.
Blake |
#24 | |
Re: Sway bar
I added a front bar from a Heavy Half Squarebody C10 with the lowered brackets, then later the CPP rear sway bar along with their traction bar from Summit. It is a lot of fun to drive now. |
#25 |
Re: Sway bar
| Bookmarks |
