Old 12-15-2018, 11:46 AM   #1
Bullett
62 c10 wheel/tire advice
So I have been doing a resto on my truck and it is pretty much finished. Time to change out the wheels that were on it when I bought the truck. They are 20” wheels, and I would like to keep 20” wheels but a different style. I’m thinking maybe Torque Thrusts or something along those lines. The truck has the original axles with the drum brakes. Do you folks usually run the same width wheels all around or do you run a bit wider wheel in back? I always ran wider wheels on my hot rods back in the day but not sure that is the norm now days. Also, what backspacing should I be ordering so they fit in the factory wheel wells? I like the 20” wheels as they give the truck the appearance that it is lowered a bit. Should the wheels have the same backspacing front and rear? Thanks. I’ll post this first and then try to add pics. Each time I try to add pics to this post, I lose it all??
Bullett is offline   Reply With Quote
Old 12-15-2018, 12:06 PM   #2
Bullett
Re: 62 c10 wheel/tire advice
Grrrr! I give up, won’t let me load pics, says I’m missing some type of security token???
Old 12-15-2018, 01:02 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Many folks do stager the size and width front to back.
Like: 18” front and 20” back, 8” wide front and 9.5” in back.
I would think since you have stock front and rear, a good vendor for what you like would be the first call I’d make.
There are several vendors here that could help you out.
Good luck!!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
