12-15-2018, 08:06 PM | #1 |
1962 235 head removal issue.
Today I was about to pull of the head from the block and came across a small problem. As I was about to pull the last push rod, I faced a clearance issue. Can’t pull it out because the push rod sits under the firewall concave and maxes out when it his the firewall. I’m not sure what to do because it seems obvious that I can’t pull it out with it stuck in there.
Also the head was coming off pretty easily, and I see some rust on the block. Pretty sure that means it’s been leaking for a while right? Hope I don’t have to resurface the block or the head. Any help would be very appreciated, I would love to be able to drive my truck on Christmas. |
12-15-2018, 09:15 PM | #2 |
Moderator
Re: 1962 235 head removal issue.
Is it still protruding into the block when it's lifted all the way up as far as it will go?
12-15-2018, 09:18 PM | #3 |
12-15-2018, 09:19 PM | #4 |
Moderator
Lift tail of trans with a jack, tilt engine forward, should clear.
12-15-2018, 09:44 PM | #5 |
Moderator
That's an awesome idea jayoldschool has. I had a GMC Panel that sat under the "tunnel" so to speak and I didn't think I had that problem when I removed my head once. Different year/series though.
12-15-2018, 10:17 PM | #6 |
12-15-2018, 11:29 PM | #7 |
12-16-2018, 01:23 AM | #8 |
60-66 Nut
I have heard of people drilling a hole in the cowl to enable removal of that pushrod and then plugging the hole with a rubber plug or similar.
12-16-2018, 01:59 AM | #9 |
12-17-2018, 07:24 AM | #10 |
I would just loosen up tranny and raise the back Been there done that.
12-17-2018, 04:33 PM | #11 |
12-19-2018, 11:24 PM | #12 |
What engine oil are you using ? looks very clean .
12-19-2018, 11:38 PM | #13 |
12-19-2018, 11:50 PM | #14 |
Does anyone know which is the best way to clean out the threads on the block?
12-20-2018, 02:15 PM | #15 |
Moderator
Is this a "trick" question?
12-20-2018, 07:00 PM | #16 |
Never Ending Projects
Use a cleaning tap, which are made to clean threads without cutting new ones. Use some WD-40 or similar to help the tap clean up and not bind. Do not use a regular tap as you do not want it to cut the threads.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
12-20-2018, 11:24 PM | #17 |
Take a normal bolt, cut 3 or 4 vertical slots in the threads and it will do the same thing as a cleaning tap
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
12-21-2018, 12:00 AM | #18 |
I’ve never heard of that, okay thank you for that info! Can I get a cleaning tap at Home Depot?
12-21-2018, 12:01 AM | #19 |
12-21-2018, 12:37 AM | #20 |
You can take one of the original bolts to any hardware store and use the measuring thingys to find the size. While you are there, you can get a bolt or two to cut slots in
12-22-2018, 12:34 AM | #21 | |
Just for reference this is the regular taps, not the cleaning kind right? I’m going to still cut slots into a bolt I found. Is there a certain I’m supposed to cut slots into the new bolt? |
12-22-2018, 11:15 PM | #22 |
Sorry to respond so late, haven't been on my laptop all day.
That tap looks like a regular tap, not a cleaning one. To cut the bolt, use a dremmel or something of the sort and start at the bottom of the bolt, then go in a straight ish line directly up towards the head of the bolt. You don't have to cut extremely deep into the bolt, just get a little past the deep part of the threads. Sorry it's hard to explain without a pic, but my buddy at the restoration shop I worked for showed me this trick. Unfortunately, I don't have a dremmel to make one, otherwise I would
12-31-2018, 05:46 PM | #23 |
