Old 12-16-2018, 12:23 PM   #1
69 customcamper
Active Member
weatherstrip adhesive remover
Hey Guys,
I am in california so I have no access to the weatherstrip adhesive remover that worked so well. Any ideas ? Have you used anything else? Paint is good so no grinding or sanding LOL.
69 customcamper is offline   Reply With Quote
Old 12-16-2018, 12:47 PM   #2
RodnRudy
RodnRudy's Avatar
Re: weatherstrip adhesive remover
Try a slow drying enamel reducer or a pre sanding cleaner. Surely you can find either of these in Cal. as body shops use these products.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 12-16-2018, 12:48 PM   #3
Grumpy old man
Grumpy old man's Avatar
Mineral spirits or NON ethanol gas.
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 12-16-2018, 01:08 PM   #4
Area54
Area54's Avatar
For years I had used the 3M adhesive remover until I had one of our work trucks wrapped. He used denatured alcohol. Works better & a fraction of the cost.
Area54 is offline   Reply With Quote
Old 12-16-2018, 01:20 PM   #5
69 customcamper
Active Member
Mineral spirits (Or at least the ca blend) does not work. I will try the other items listed above ! Thanks!
