Old 12-16-2018, 06:22 PM   #1
Jorion04
65 fuel system
Hi guys. I need a little guidance. I’ve look but can really find what I need. I need to figure out what fuel tank to use. I can’t afford the boyd stuff. This a low budget swap. Thanks in advance
Jorion04 is offline   Reply With Quote
Old 12-16-2018, 07:24 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 65 fuel system
Welcome...is this for a LS swap into a 65?...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-16-2018, 07:51 PM   #3
Jorion04
Re: 65 fuel system
Yea sorry. Ls swap into a 65 C10.
Old 12-16-2018, 08:22 PM   #4
Macdaddy1
Re: 65 fuel system
I used Tank INC universal fuel tank which fit almost perfect. I had to grind a wee bit on one side to allow it to drop in. I also used there fuel lines. If i had to do it all over again Tank INC makes a early mustang tank that I think would fit also.
Macdaddy1 is offline   Reply With Quote
Old 12-16-2018, 08:46 PM   #5
Jorion04
Re: 65 fuel system
I just found one from lmc. It sayscan be used for efi. Has anyone on here used that one?
Old 12-17-2018, 10:48 PM   #6
Bret B
Re: 65 fuel system
I used a Boyd's tank. Bought everything from Pro Performance. Get the tank, aeromotive pump, and regulator with hose all at one time. There are other tanks, LMC has one, Brothers offers a tank, CPP, and a few others. That is if you want a rear, under bed tank. I have no clue what is available for OEM location with pump and so forth.
1965 Chevy short-step side, work in progress....
............................____
..................______l/___\____
.................|_/(0)\_ll____/(0)_l.
Bret B is offline   Reply With Quote
Old 12-18-2018, 08:39 AM   #7
Jorion04
Re: 65 fuel system
Thanks. I think I’m gonna go with rear under bed. It’s looking like I might use lmc kit. A long with walbro 255 inline pump. I think that might be a good low budget set up.
Old 12-18-2018, 06:37 PM   #8
verdell
verdell's Avatar
Re: 65 fuel system
If you have room under the bed, a Blazer tank (with built in pan) can be had for around $100. Sending unit $80, AC delco fuel pump $40, Corvette filter regulator $50 (if needed). Run some fuel lines and go!
verdell is offline   Reply With Quote
Old 12-18-2018, 07:26 PM   #9
Jorion04
Re: 65 fuel system
What yea blazer? And s10 blazer or full size?
