Help ID 4L60E transmission part
This part is leaking on my 4L60E transmission. It looks like it might take an O-ring. Can someone help me identify what it is called?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Re: Help ID 4L60E transmission part
It is a VSS or Vehicle Speed Sensor used for computer information for FI and trans control or elecrtronic speedometer depending on year.
It does take an o-ring. Also you can pull that part out and that is where the speedo stuff would go if you need that instead. Jim
Thanks. I ordered an O ring
Mine was leaking also,replaced o ring, I put a dab of RTV to give it extra seal,no more leak
