Old 12-16-2018, 09:08 PM   #1
57larry
Firewall modification for American Autowire
bought the American Autowiring kit for my 68. The square hole for the wire bulkhead needs to be enlarged. What have you guys cut the firewall with? Dremel cutoff tool?
Thanks, Larry
57larry is offline   Reply With Quote
Old 12-17-2018, 12:06 AM   #2
TruDom
Re: Firewall modification for American Autowire
yep a dremel cut off wheel attachment.
easy to do from the engine bay side.
TruDom is offline   Reply With Quote
Old 12-17-2018, 12:55 AM   #3
68 P.O.S.
A dremel with a cutoff wheel is what I used as well. I also used one of the grinding stone attachments to smooth the sharp edges.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 12-17-2018, 09:27 AM   #4
Mike C
Mike C's Avatar
I tried opening it up with a jigsaw and a metal blade while we have the front clip off, but that was a bust. Firewall was not flat enough for the short metal cutting blade. Used a 4” grinder with a cut off wheel, but I see the Dremel as being the best tool if you are under the dash.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-17-2018, 09:44 AM   #5
notsolo
notsolo's Avatar
You can drill rows of 1/16" holes and then file it flat...not fun even with the clip off.
notsolo is offline   Reply With Quote
Old 12-17-2018, 11:19 AM   #6
57larry
thank you everybody, I guess I'll use the dremel cut off wheel.
how did you cut it from the firewall side, flip the template over? thanks, Larry
Old 12-17-2018, 11:36 AM   #7
notsolo
notsolo's Avatar
I think you could flip the template.....I drilled mine from the inside, filed from both sides. Nice thick sheet metal, makes my neck hurt just thinking about it...Good
Luck...
Old 12-17-2018, 12:27 PM   #8
68 P.O.S.
I did it from the engine bay. Seemed a little easier to me than from in the cab. Be careful of the sound deadener/insulation if you have it installed or trim it back cause it will catch fire.
