Rear gas tank
With all rear gas tanks. Do you always have to cut part part of the bed support rail. In order for the bed to fit correctly on the frame. Or is there other rear gas tanks thank you can purchase that you won’t have to cut it.
Thanks, Ramiro |
Before and After
Re: Rear gas tank
Pretty much all the blazer tanks need to have some of the bed support removed. About 2” between the frame rails should do the trick.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
Re: Rear gas tank
Re: Rear gas tank
Re: Rear gas tank
Boyd tanks fit without cutting any bed or frame supports......this under my 72 Blazer...C10 same...I can post long bed photo if you need it.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
Re: Rear gas tank
![]() Join Date: Nov 2012
Re: Rear gas tank
I like that!! How many gallons capacity is it? Maybe I will get one for my 67 GMC 3500 someday...?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
Re: Rear gas tank
These are baffled aluminum tanks, about 17 gallons. Mine is a side fill...these photo's from 71 long bed, not using the efi on this 1. Tanks are set up either way, Spring shackle is right where the fill is, if your going lower you may want a top / bed fill....I have a brace on the rear cross member, from extra trailer hitch, nothing to do with the tank.
Re: Rear gas tank
I installed a tank from this link
https://www.performanceonline.com/19...ank-19-gallon/ it was a aluminum tank with baffles, 19 gallon. under $439 fit great and no cutting required. THe best part for me was that the back of the tank was angled so you don't see the tank. that's what I didn't like about the blazer tank or some others sold online, brothers trucks etc. just have to remove bracket for spare tire. hope this helps. mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com Last edited by rockyrivermark; 12-17-2018 at 04:59 PM. |
Re: Rear gas tank
Thank you all for commenting . Some nice ideas to consider.
![]() Join Date: Sep 2010
Re: Rear gas tank
Boyd's tanks fit like a glove...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
![]() Join Date: Apr 2005
Re: Rear gas tank
I used the LMC bed fill tank PN 32-5981. It's basically a blazer tank with a modified top so you don't have to cut into your bed supports. Cost was $150. I then installed an Aeromotive Phantom fuel pump for my LS swap. I think there is a YouTube video on Stacy David's Gearz on this tank's installation. But remember you have to cut a hole in the bed to fill it.
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675 2011 Dodge Ram 1500 2012 Camaro ZL1 |
#13 |
Re: Rear gas tank
Old_Truck is the LMC tank baffled? I was looking at the same setup and fuel pump for my LS swap but was worried about pump starvation. I have a 4x4 so a bit more movement in the back than a 2X that I need to plan for.
Great thread! |
#14 | |
Re: Rear gas tank
thanks, Ramiro |
#15 |
landarts
![]() Join Date: May 2005
Re: Rear gas tank
Went with a Ford Mustang tank with 90 ohms sending unit from Tanks Inc., added a magnetic gas filler door from Yogi's, all welding in a smoothed out. Also changed out the standard cap for a no remove cap, just push the gas hose filler through the cap and fill. This fit with out any modifications to frame and the cost was reasonable.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
#16 | |
Re: Rear gas tank
I think it is around 12 inches from top to bottom which is right at the limit of the Aeromotive Phantom standard kit. (They have a longer pump arm available separately if needed.)
#17 |
Re: Rear gas tank
I ordered a 1959 Impala tank from Amazon for about $90 . I made the brackets and straps from some scrap , bought some floor matting from TSC and glued to the straps to protect the tank . Moved the cross member and cut an opening for the filler neck . About 4 hours and done . I’ll pick up a flip down license plate bracket from the junk yard to complete the installation.
#18 |
Re: Rear gas tank
I put a 31 gallon late 70s blazer tank in my 72. It fit right in there without modding the bed. I modded the blazer crossmember and bolted that in for the rear support. Easy day with factory straps and skid plate. The hard part to all this is how to fill it. There are a million ways to accomplish this. I ended up cutting a hole in the bed and running the filler tube up the bedside next to the stake pocket. This allows me to still put gas in it when being used as a truck. Alot of slicker ways for the cruising crowd.
#19 | |
People know me
Re: Rear gas tank
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
#20 |
Re: Rear gas tank
The Impala tank is 29.25” x 27.75” x 7.25” so it doesn’t hang below the frame much at all . It’s a 16 gallon tank . I’m pretty happy with the way it turned out . Just waiting on the weather to improve so I can pickup a fold down license plate bracket and finish . I may have to shorten the fill neck an inch or so . Advance Auto had the same tank for about $100 delivered to the local store .
#21 |
Re: Rear gas tank
I used the LMC tank, fit with no cutting. Also used a Harley Davidson Cap in the bed rail works great
#22 |
Re: Rear gas tank
Thanks everyone for all the info. A lot of options to consider.
Thanks , Ramiro |
#23 |
Re: Rear gas tank
Currently my 68 head the lmc side fill... had to notch the crossmember and the filler neck made it a tight tight fit for routing... also the filler kneck is small, so filling up takes a while, and it's not ready for EFI, having to do inline pump, just bought a boyd tank,
#24 |
Re: Rear gas tank
#25 |
Re: Rear gas tank
I wanted additional capacity for my 71 4x4 and went with a 31 gallon Blazer tank. Did some work to mount it as close to the bottom of the bed as possible, and I fill it in the wheel well which is an option with a 4x4 that is raised a little bit. I have about 50 gallons capacity now, including the original tank.
