12-17-2018, 04:47 PM | #1 |
Alternator wire
In this pic you'll notice that the wire I'm holding is disconnected from that clip going into the alternator. I've got 14.50 volts at the battery when running so its charging properly, so what is that wire for?
I traced the wire and it goes into the harness for the voltage regulator but it doesn't actually connect to the regulator, I'm guessing that this alternator is internally regulated so previous owner bypassed the regulator?
1968 C10 |
12-17-2018, 05:09 PM | #2 |
Re: Alternator wire
See if it goes to an Ammeter. That's my bet.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
12-17-2018, 05:23 PM | #3 |
Re: Alternator wire
Ah yes I bet you are right
1968 C10 |
12-17-2018, 05:46 PM | #4 |
Re: Alternator wire
I don't have a schematic handy but that may be full-fielding your alt. That means it's not being regulated and you could cook your battery. It might cause possible acid damage in the battery tray area. 14,5VDC is too much. That wire looks like it's in pretty brittle and not good shape. Good news is that those terminals are pretty common in auto parts and the terminals and plug are easy to replace.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E 2018 Dodge Ram 2500 HD R/C |
12-17-2018, 05:53 PM | #5 | |
Re: Alternator wire
1968 C10 Last edited by bob8619; 12-17-2018 at 06:31 PM. |
12-17-2018, 06:38 PM | #6 |
Re: Alternator wire
I have to rev the engine to get the alternator to charge does that mean this is one of the single wire alternators? And if so, does that change anything in terms of that wire?
1968 C10 |
12-17-2018, 06:57 PM | #7 | |
Re: Alternator wire
The disconnected wire is for the "GEN" light (if your truck has the standard warning light cluster). That circuit also serves to "excite" the alternator ... in other words, cause the regulator to "switch on" when the ignition is on. Many regulators will "self excite", without that wire connected if the engine is revved up a bit, which sounds like what you're experiencing. In addition to re-connecting that wire to the alternator, you'll probably have to install a jumper at the former external voltage regulator plug to complete the circuit. Try searching this site for external to internally regulated alternator wiring and it should turn up some posts by VetteVet with diagrams. |
12-17-2018, 07:10 PM | #8 | |
Re: Alternator wire
I reconnected it and did the jumper and now my alternator is self exciting which I'm pretty happy about. I don't think I have a generator light on my dash, at least it doesn't say GENERATOR on it like the ones I've seen. Is that same wire supposed to power the amp gauge on the dash though?
1968 C10 |
12-17-2018, 07:15 PM | #9 | |
Re: Alternator wire
12-18-2018, 11:17 AM | #10 |
Old member
Re: Alternator wire
12-18-2018, 11:21 AM | #11 | |
Re: Alternator wire
12-18-2018, 01:02 PM | #12 |
Re: Alternator wire
Here is a simplified version of the charging circuit and it's from GM.
Notice that the resistance wire and the generator light, both terminate at the ignition switch and at the bulkhead connector. This resistance wire is in the dash harness wiring. This resistance wire is in the harness, whether it has the Gen light or no light. As mentioned by someone above, a Generator Gauge is in a different circuit. This resistance wire is the same in the '60s truck with external regulated alternator and in the '70s truck with internal reg alternator. The voltmeter shown in the drawing was there for testing purposes.
'67 GMC 2500, 292, 4spd, AC |
12-18-2018, 02:00 PM | #13 |
Re: Alternator wire
that red wire going from the plug to the post in back of the alt could be draining your battery. it was on mine. I had to run the red wire in the plug to the post on the fender where the battery hooks up
1967custom |
12-18-2018, 05:12 PM | #14 |
Old member
Re: Alternator wire
That has nothing to do with where the wiring goes. You don't change out the wires to the truck just to install a newer alternator. You either jumper the external regulator out are run the wires from the regulator to the alternator. Nothing else changes so the wires run to the same places.
